B&O front speakers worth changing?
WheresMyCar
Steph
New Orleans
Audi A5
I was going to change out most of my speakers but looking at the B&O fronts, they aren’t the same cheap paper they installed on kick panel or rears. I was gong to change them out with Kicker CS. Is it even worth it? Does anyone know the type of speakers are on dash of the B&O?
Ford Bronco B&O front speakers worth changing? BBADE123-ECF6-4D3C-B4FC-10E5AC433608
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Yep, pretty cheap. The top threw me off. I think my next question is whether bass blockers are truly necessary.
Ford Bronco B&O front speakers worth changing? E869F2CC-D001-4931-9BD3-1D5C32A467DE
Ford Bronco B&O front speakers worth changing? 9A15C359-562E-4B17-AA9A-63EFDF09D715
talbot
Calgary
2dr BL AMB
Yes change them all
consensus is the kick panel speakers are the least beneficial to replace
ive done all the front and rear pods, much better
next weekend i’m also going to try the kick panels to see if any improvement
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Yes change them all
Is there benefit to changing the sub or Center on the B&O? Those seem the hardest. Waiting on a few parts to finish installing the kick panels.
Frankly, I never intended to rip any of the B&O speakers, but I just can’t deal any longer.
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
I think there will be a significant difference with changing the Kick panel speaker. Look at the difference in quality. The 6.5 and rear 4” are paper cones.
Ford Bronco B&O front speakers worth changing? F22090E7-3D15-46D2-A653-044227B18E79
talbot
Calgary
2dr BL AMB
center for sure was an improvement
plus some poly fill and/or dynamat
to me was a huge difference
note that you will get good results with speakers that have high sensitivity if not adding an amp with the b&o
i havent replaced the sub, but might next time i feel like pulling the panel out
from what ive read most who swap the sub also put in an amp
ATM i‘ve got good results with swapping all the 4”
I did try kicker’s in the kick panels last weeknd but it didnt sound as good as stock
i ordered some hertz 6” that ill try next weekend to see if they are any better
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
What kick panel speakers did you try first? I have all Kicker CS going in.
talbot
Calgary
2dr BL AMB
yeah all the b&o speakers are crap
i think with those kickers it should be an improvement
WheresMyCar
WheresMyCar
Steph
New Orleans
Audi A5
Seems like it would be tough to add the mating in the fronts, there’s a deep cavity that is open. I was going to use the Boom Mat. I added the sheets in the cavity of the 6.5, cut the foam off the bottom because I read it blocks/muffles all the bass.
Did you install Bass blockers on any of the 4” speakers?
Ford Bronco B&O front speakers worth changing? 9E3C0797-64C8-4D90-8413-9F622BF47137
talbot
Calgary
2dr BL AMB
no I didn't
but when I do the kick panels again next weekend I'll most likely put blockers on the 4"
kingsingh14
Rohan
Birmingham, AL & Bowling Green, KY
2023 Ford Bronco BL SAS LUX 2.7
For me personally, it was absolutely worth swapping out the sub. While I was back there I added Kilmat and eliminated 90% of the rattles. I’d say the Kilmat made the biggest difference, but over all I’d definitely replace the sub and add an amp
