Aux Upfitter Switch Part Numbers - Super Stickie
ritchie
2022 Big Bend
BIG THANKS TO RUSTYBRONCO!!!!
Parts Needed (Confirm W/Your Local Ford Dealer For Your Specific Model -
Outerbanks Lux
Overhead Trim Panel: M2DZ-78519A70-JC (Includes 6 Aux Switches)
A-Pillar Wire Harness: M2DZ-14335-C
BCMC/Fuse Junction Panel Assembly (Fuse Box): MB3Z-14A068-NBA (replaces under the hood fuse panel)
A-Pillar Wire Harness: M2DZ-14335-G
BCMC/Fuse Junction Panel Assembly (Fuse Box): MB3Z-14A068-Z (replaces under the hood fuse panel)
A-Pillar Wire Harness: M2DZ-14335-J
Tools needed (Shop Dog Optional) 🐕
1. Trim panel tools
2. 7mm socket
3. 8mm socket
4. 10mm socket
5. 15mm socket
7. Torx T20 bit.
8. Torx T30 bit.
9. J2534 Compliant Scan Tool
below is his post:
https://www.bronco6g.com/forum/thre...riteup-instructions-photos.35388/post-1168276
writeup-instructions-photos.35388/
the video of how it all works (with the installation!)
Ducati1098
Part numbers appear to already be on the 2nd thread you linked. Why make another one?
Also some part numbers will be different depending on model/options.
ritchie
2022 Big Bend
Trying to create a "FIRST PAGE" posting the information...
(I edited since your reply)
Lots of the info here is from years ago where members were searching for solutions - so all of the important info gets buried.
Stevenson James
Chicago
2024 Bronco
Outerbanks Lux
1. Trim panel tools
2. 7mm socket
3. 8mm socket
4. 10mm socket
5. 15mm socket
7. Torx T20 bit.
8. Torx T30 bit.
below is his post:
For the outerbanks Luxe are the actual aux wires prerun and near the firewall wire bundle?
CowboyLawyer
Matt
San Antonio, TX
2023 4DR Bronco
Hard to justify Middletown Motorsports $900 package with these parts when I just sourced them for $650…
JustWideman
Justin
justwideman.com
Bronco Big Bend '24
Yeah, I saw their video but knew they are getting OEM and marking them up, I was curious about the parts numbers, and now we know!
Rivers90
Ben
Southern California
2 Door Base Sasquatch
Did any of this change for the 2025's? I cant find a Fuse Box that says 2025 all of them say 2021-2024.
SWFlGuy
Guy
Fort Myers, Fl
2024 F250 Tremor 2025 Bonco
I’m interested in the same thing
