Auto Stop Start on my 2.3 6sp
mul1gan
Peter
Has anyone seen or purchased this auto/stop bypass? I was looking at the install video, what would happen if I just got in there and disconnected the plug for the auto stop button??
Autostop Eliminator for the 2021-2022 Ford Bronco
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
If you disable the button, you just won't be able to disable ASS
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
I used ForScan to disable mine. It can still be enabled easily by pressing the dash switch twice.
Aman
Aman
Northern NJ
Aman
Aman
Northern NJ
Why when it’s $100 vs a $20 adapter and Forscan?
Simply that ASE remembers your previous setting and essentially depresses the ASS button for you. FORScan tricks the Bronco into thinking that you are providing an input, I believe steering, that you are not. I use FORScan for plenty of things, but not to disable ASS.
mul1gan
Peter
how much is the forscan? wont I have to buy the dongle as well or is that the adapter you are referring to?
F OR D
BD Green Machine
what is the impactful difference, or benefits of ASE vs forscan? i'm on the fence for this one.
Aman
Aman
Northern NJ
I believe FORScan tricks the computer into thinking that you are actively giving steering input which prevents the ASS from engaging. I’m sure it’s fine, but I don’t want the computer thinking I’m doing something that I’m not.
The ASE simply remembers the last state ASS was in and “presses” the button for you if needed. To the vehicle it’s the same as if you pressed it manually.
BigBoyJon
Jon
Boca Raton Florida
2022 Bronco Black Diamond
I found it to be straightforward and 100% worth it. 10-minute install. If you skip to about 4 minutes in this video I talk about the process and tools I thought were helpful
cyberfalco
Tony
Conway, AR
