Auto start stop disable with Ford's FDRS system?
jlj4660
Jeffrey
Clayton NC
2021 Bronco Badlands, 2023 Bronco Outerbanks
Does anyone know if this can be disabled with Ford's FDRS system
jlj4660
Jeffrey
Clayton NC
Thanks I already have the Ford setup and have been using. Have never used Forscan but may try
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
Check the Forscan spreadsheets for the Ranger, should use a similar body module.
bmclain
Albuquerque, NM
2013 Ford Explorer, 2021 Ford Bronco Badlands
Does disabling it in Forscan just set it to off by default, or does it disable it? Just wondering if the auto stop eliminator adds anything over the Forscan route.
Aman
Aman
Northern NJ
I believe disabling it in Forscan simply tricks the vehicle into thinking you are applying pressure to the steering wheel, thus preventing auto off. Autostop Eliminator saves your setting and automatically applies it when you start the vehicle. Forscan is great for a lot, but I purchased the Autostop Eliminator as I don't like the way Forscan handles this.
Herbie
Alex
Cleveland OH
2022 Badlands
Aman did you install the Eliminator yet? I have ordered it for my vehicle (that I am waiting on), but plan on installing it right away. The video I watched makes it look pretty straight forward, was it? Did you have any issues removing the requisite paneling. Thanks
Aman
Aman
Northern NJ
No sir, my Bronco is scheduled to be built in December, so haven't had the opportunity. As you mentioned, the video makes it look dead simple, so should be a fifteen minute job.
Herbie
Alex
Cleveland OH
2022 Badlands
So we are in the same boat, but you will have yours sooner so you can guinea pig it for me and report back. Should be easy, hardest part should be pulling apart the paneling carefully and reinstalling it so you don't break any clips.
KTP 30
Ray
Southern Indiana
21 Wildtrak 23 Bas Squatch 93 Mustang 87 mustang
Am I missing something here the steering wheel has an effect on the auto start?
Aman
Aman
Northern NJ
Power steering requires the engine to be running, so I believe, Forscan tricks the vehicle into thinking that you are turning the steering wheel a bit which keeps the engine from shutting off.
Gpscharron
Claude
Waynesville, NC
2021 FORD Bronco, RV- Ford E450 (Thor Vegas 24.1)
There’s a plug on the negative battery terminal. Just unplug it.
Who iz
Otis
End of the Oregon trail
F250, 4Runner, Jimmy
Forgive my ignorance.
So I do not need to purchase an eliminator?
Simply unplug (image please) what plug to disable the auto stop/start?
AaronW
Aaron
Phoenix, AZ
i have it installed. Very easy installation. Just follow their video. Takes maybe 20min to do.
