Armadillo Designs Aluminum Hardtop
Dtrimpi87
2024 Bronco Badlands Sasquatch
Speaking of water, has anyone had issues with their latches leaking? At first I thought it was between the latch and the gullwing itself but it seems to be well sealed and I did tighten up 2 latches. After a good wash it seems like the water is coming in around the spring area inside the latch and drips down off the arm Inside. Not sure theres any way to actually seal that.
Ford Bronco Armadillo Designs Aluminum Hardtop 20260222_120257
Ford Bronco Armadillo Designs Aluminum Hardtop 20260222_120310
Dtrimpi87
Now for the shelf I was installing in case anyone is interested. I was looking for some storage up towards the roof in the rear but the M2M attic shelf wasnt enough for what I was needing. I found this shelf from Hooke Road that offers about 7.5" of space between the shelf and the top of the roof. The front of the shelf drops down to give you access for sliding your equipment/supplies up in there. I did have to modify that piece a bit. I just had to cut 2.5" in each side off the front panel of that drop down piece to accommodate for the struts of the Armadillo hatch. Just need to clean up my cuts and touch up the paint. Quote happy with it.
Ford Bronco Armadillo Designs Aluminum Hardtop 20260224_174949
Ford Bronco Armadillo Designs Aluminum Hardtop 20260224_180248
Skeet McGeet
2022 Bronco Wildtrak
New member here and first post. Ive had my Bronco a little while now and have done my share of mods, but this top is my favorite one by far. There's not really any comparison with the other tops available on the market. If you're on the fence about it like I was originally, don't be
Ford Bronco Armadillo Designs Aluminum Hardtop 20260212_105624
Ford Bronco Armadillo Designs Aluminum Hardtop 20260212_105441
Ford Bronco Armadillo Designs Aluminum Hardtop 20260212_150531
Ford Bronco Armadillo Designs Aluminum Hardtop 20260212_105327
Ninjak
Miami
Welcome to the Armadillo Crew!
Living that Slant Back Life!
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
Anyone having problems with the sound deadening losing adhesion to the removable top panels? This started a couple months ago, where I get in the Bronco and the corners/sides are peeling back. I’ve tried some 3m headliner spray, but not holding up more than 1-2 days and it’s just getting worse. Note that when I went for the install nearly 1 year ago they had the wrong color installed and had to quickly swap them out to the right color. I expect they may not have fully cleaned off the old 3m stickum!
Suggestions welcome on a good adhesive? I’ve read DAP Weldwood Landau Top & Trim HHR Solvent is pretty good…
mangelo
San Francisco
2021 Badsquatch LUX Softtop 4 Door Carbonized Gray
Could def use the space, didn't know mod was possible to make work! I also have DV8 rear window molle panels on inside of roll bars, maybe I have to mod more or it's impossible? Curious to see closer pics of how u modded / mounted 🙏
Thanks for sharing, VERY cool!👏
Dtrimpi87
The DAP adhesive is what Armadillo is recommending now over the Gorilla adhesive they used to recommend. I bought some but I have not used it yet. From what i've read about it its pretty permanent once it hardens so as long as it's applied right, shouldnt have anymore issues.
https://www.amazon.com/dp/B092NJH6XL?ref=ppx_yo2ov_dt_b_fed_asin_title
Dtrimpi87
I will get some better pics this evening when I get home.
Dtrimpi87
Here you go. You can see how it attaches to the roll bar and the cuts I made. I cut 2.5" wide and about .5" deep. Looks like it should fit with the DV8 molle panels from what I can see in their site.
Ford Bronco Armadillo Designs Aluminum Hardtop 20260226_171812
Ford Bronco Armadillo Designs Aluminum Hardtop 20260226_171818
Ford Bronco Armadillo Designs Aluminum Hardtop 20260226_171832
Ford Bronco Armadillo Designs Aluminum Hardtop 20260226_171850
Ford Bronco Armadillo Designs Aluminum Hardtop 20260226_171902
El Diablo
Roberto
San Carlos, CA
2018 Tesla Model 3 and 2022 Ford Bronco
I've had lot's of problems with the original adhesive not sticking and Fabian acknowledged it was a bad batch. Used the gorilla spray adhesive with marginal success. Haven't tried the DAP yet. Have several pieces that have come off that I just haven't had the time and energy to fix. Otherwise the top has made the cabin much quieter and get compliments about how good looking the slantback is.
mangelo
San Francisco
SO helpful, thank you and nice job!
M
Pseudoko
Vince
Chino, CA
My 2 Feet
Dillo Family Portrait from UBB
Ford Bronco Armadillo Designs Aluminum Hardtop IMG_4237
