Armadillo Designs Aluminum Hardtop
Slei
California - Bay Area
2023 Ford Bronco, GTI, 1972 Jeep CJ5
I find it so interesting that decibels aren’t a linear measurement.
Anyway…Unfortunately I have a Garmin. Are these noise apps really that accurate? My “earhole” noise app suggests it is greater than a four decibel decrease, but that is based on the elimination of wind noise. It’s noticeable. I believe Armadillo does have some decibel testing results on their website but I could be mistaken.
Between the Katzkin and Armadillo hardtop the bronco is now a tolerable vehicle on the road.
This^^^.
db are a great way to measure audio systems or a specific job based risk but kind of suck for perceived volume. Depending on the frequency you may not even hear what is being picked up by a meter. Also as you say most apps are on non calibrated devices.
I have the Enduro 2 solar. I don’t believe it has a microphone.
Makes ya wonder though why a watch noise app would be preferred over a phone app. Are the microphones more accurate on the watch?
Unfortunately most of the time watches and phones are A weighted, not calibrated, and as such are not good at measuring perceived noise levels. C or better yet Z rated meter will give you a better idea of what the noise damping of the top is but only the peak noise level and that may not be the noise you are most aware of.
I have all the equipment to make environmental db measurements. If people were interested we could go deeper and do a full analysis to confirm the claims, showing what frequencies the top actually cuts down, and making some high quality balanced recordings of the sound.
Only issue is my top is not due till later this year, so unless someone local who is getting a top in the near future wants to partner up on it It will be 3 or 4 months till I can do so.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
This^^^.
I think there's somebody else in the Bay Area on this thread that has one?
SierraBronco
This^^^.
If you’re going to be at the winter jamboree or united by bronco we’ll be at both events if you want to do some testing.
Slei
I know of one person getting one before me. Ultimately would be best to do a before and after on the same vehicle. I think they are upgrading from soft top and Im upgrading from (Mic)Hard top so maybe we can do both variations.
Slei
Thanks but doubt Ill make either. Was considering making the drive for United by Bronco but work got in the way.
brocosaurus
US
brompo
This^^^.
Super cool of you to drop that knowledge and also be willing to test it for those of us interested!
Gtrekker
Gary
NJ
So I decided to go give this a try. It's a cool night in Miami, 57. Slight breeze. Test conducted using the noise app on the Apple Watch.
Vehicle Jessabelle:
2.7 twin turbo with Injen CIA, Injen Charge Pipes, Injen Down Pipe, Turbosmart BOV, Magnaflow Street Series Exhaust. Tires Cooper Discovery STT Pro 37x12.5x17 Rigid Radiance Series 40' lightbar.
@40 mph 68~70 db
@50 mph 70~72 db
@60 Mph 72~74 db
@70 Mph 75~77 db
@ 80 mph 77~79 db
The db's did not go out of the green zone and stayed under 80 db. @90 it did go over 80 to 81.
As I said before, most of what I hear is tire noise and some lightbar whistle. I also hear my turbos and blow-off. (NEVER will get tired of hearing that):like:
So this top is a lot quieter. I had only done one test in my soft top when I was considering getting the dirty dog liner, and yeah it started at 80db at low speeds. So very satisfied with the results.
Thank you and enjoy your build... Nice setup!!!
SierraBronco
Sooooooooooo…their interior storage panels really do provide a ton of storage. Awesome use with the gullwing doors. Trying to only put lightweight stuff up there but wow have they opened up space in the toolbox. And having all the extra headroom up front makes the overhead storage that much more versatile. Handheld radios now clip in from the top and it allowed us to be pretty lazy about needing to take the top off try out different mounting options to hold the winch remotes.
Only “negative” so far is that the lack of wind noise does make it to where we can hear the portals. It’s obviously not terrible and just like before the conditions need to be just right. (This isn’t a negative at all. Straight cut gear noise > wind noise all day every day)
Ford Bronco Armadillo Designs Aluminum Hardtop IMG_4888
Ford Bronco Armadillo Designs Aluminum Hardtop IMG_4889
Ninjak
Miami
@SierraBronco : That is not a bad place for the fire extinguisher. I run the DV8 as well, I was trying to figure out where I would put one.
Did my first wash today, no problems there. Ran it through the touchless wash I always go to. I thought I would hear the water hitting the roof...nope. Had my music on, not even loud, and I paid it no attention. Also interesting, the rear molle has some sort of way to drain out water. I was wondering how it would work.
SierraBronco
We’ve had the unfortunate ability to test out that fire extinguisher location and I can confirm that it was a very useful spot in an emergency situation. We’re going to put the normal dry element extinguisher in the back as a backup or for fires that aren’t under the hood/not a vehicle. But the non-corrosive $450 extinguisher will be up front. Already had the experience of the fire melting things and not being able to open the hood as a result-I can see the same thing happening in the back.
mangelo
San Francisco
2021 Badsquatch LUX Softtop 4 Door Carbonized Gray
This^^^.
@sleidel Glad to offer up my 2021 4 door Badsquatch V6 soft top for audio testing if it helps, I'm in SF. Gratitude for having the knowledge, the gear and kindness to test for the benefit of the community!
Pseudoko
Vince
Chino, CA
My 2 Feet
When I do my road trip to Texas for the install I can buy a decibel reader off Amazon but that won’t be until after I get my install scheduled.
Slei
Did a quick test of the mounting for sound level and audio today. (Sorry for the blurred windows realized after the fact the neighbor kids were in the shot.) Makes me wonder if I should do the same for Exhaust systems?
Ford Bronco Armadillo Designs Aluminum Hardtop 20250112_145322 copy
@Pseudoko make sure to set it for C weight (or Z/Flat if you buy an expensive one) and set it to slow if your going to hand hold it. Looking forward to what you find out.
Ford Bronco Armadillo Designs Aluminum Hardtop dba.dbc_
@mangelo Thanks Ill message you. @El Diablo also offered to let me do before and after install measurements.
Pseudoko
Vince
Chino, CA
My 2 Feet
wasn’t going to buy anything expensive since I’d only probably only use it for this study. But figure a road trip across the country to get the top installed will give you guys some info of the before and after.
Slei
No worries, Anything over $25 should have A/C weighted. Meters all default to A so if you get one you have to set it to C. If its cheeper its likely to only have A and probably only marginal better than an app on your Phone. Still its all Data and welcome.
