Are the Bilstein shocks worth it?
#Broncolife
Dan
NJ
I added 6112 today. I normally don’t post, but I was so impressed with the ride quality I had to share. It’s a completely different truck than the factory Sasquatch coilovers. No more nose dive when stopping. No more rattling my teeth over pot holes. What a difference. Only complaint is the printed lift heights. The rear yielded .25” less than printed, so I had to lower the front to level the truck.
GNFITR
Auxvasse, MO
23 Non-SAS Badlands
I recently replaced the stock shocks on my 2DR Badlands, non Sasquatch, with Bilstein 6100's. I also added 35x11.5R17 (c rated) Wildpeak A/T4W tires. I am happy with the swap.
I went with clip position 5 in the front and got about 2 1/2" lift. On the rear I went with clip position 1 and got about 1" lift. I now have about 1/2" of rake. I do have 100+ pounds of weight added to the front via winch, winch mount and an ARB dual.
Was there a reason you didn't install the bump stops? I am not sure that is a great idea if you plan to go offroad.
Rebel Bronc
Rob
Central NY
'23 OBX, 2dr, V6, 4.27
I have a stupid question. I’ve read where some people keep their oem springs when upgrading to 6112s. Is there a risk with this?
I have non sasq Badlands
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Bilstein 6112 for the win. I have friends who rave about them
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
People are keeping the Sasquatch springs for use with 6100s. For non-squatch broncos you should probably get 6112s which include the springs.
HoosierDaddy
__ Eric
NW. Indiana
For this discussion,
NON-Bilstein = Hitachi shocks.
For certain, NON-Bilstein 2drs cannot use the 6112's for some reason. They end up with something like 3.6" of lift up front, minimum.
I think , but have not yet 100% confirmed, 2dr NON-Bilstein Broncos need to purchase the Sasquatch (or Badlands??) springs and use the 6100 shock.
(again, not 100% confirmed, but I think we can also use the Eibach springs also )
Let's see if I can get this to load properly.... the same info is also posted at Bilsteins web site.
https://www.shocksurplus.com/blogs/...ZmgDsDytyMYtQh0VDMDugN9SWA-l5hOVwLM7G8KPl7D3W
6112 Shocks & Springs Lift Heights
6112series
circlipsas
4dr
sas 2drBL
4d
BL
2dr
Hit
achi
4dr
Hit
achi
2dr
#61.7”2.1”3.0”3.4”3.4”Do not use
#51.3”1.8”2.7”3.1”3.1”Do not use
#41.0”1.5”2.4”2.8”2.8”Do not use
#30.7”1.2”2.0”2.6”2.5”Do not use
#20.3”0.9”1.7”2.3”2.2”Do not use
#1Factory0.6”1.4”2.0”1.9”3.6”
