ARB twin compressor installed with Grimm speed bracket
rayofsi
Staten Island, NY
Raptor Gen2
Bought this a while ago. Never installed. This looks like it could work with a custom bracket. . Thoughts?
Not ai generated .. edited my face reflection from the intake 😂😂
Ford Bronco ARB twin compressor installed with Grimm speed bracket 20250630_172020(1)
Bschurr
NY
I thought @4x4TruckLEDs.com made an underwood mount for the Braptor but couldn’t find it on their site. Perhaps Adam will chime in with a solution for a fellow NYer…
I❤🗽
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I❤🗽
no room on a bronco raptor for a twin under the hood sorry
jtgensler
Jamison
Clarion, PA
2022 Bronco, 1996 Tacoma
You could probably jam it in there with a custom bracket, but I don't think I would.
Mine (non Braptor) is mounted there, but it's not shoved down in like that, it's at least up where it can get a little air to it.
I'd probably look somewhere else.
Also you need to think about having room for your fittings & access to the filters on the compressor to change them.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
I looked at trying to do the same. I really liked the underhood mount on my Badlands. I ended up mounting it in the back with an American Adventure labs mount. Not ideal but it’ll do the job.
rayofsi
Staten Island, NY
Raptor Gen2
the s&b filter box gave me all that space you see in the picture actually... there was a lot less with the oem filter box.
i'll be the guinea pig, ordered the grimmspeed vertical mount to try.
had this compressor sitting around for 2 years , its time to install it lol.( bought this for my f150 raptor)
rayofsi
Staten Island, NY
Raptor Gen2
For the doubters. Will probably need to drill holes in the bracket and all. Grimm speed bronco arb mount and sb air filter
Ford Bronco ARB twin compressor installed with Grimm speed bracket sketch-1751591866014
rayofsi
Staten Island, NY
Raptor Gen2
After a few hours. It's mounted via the original 2 points on the body wall. Waiting on a isolation bushing to mount on the bottom. I bent the Grimm bracket too long. Came with a 25mm bushing or something. I need half the height. Also possible to make the back side bracket work. I have very rudimentary bending skills.. has to drill one hole on the grimm.
S&b air filter needed to fit . Manifold installed as well as 40" line for a secondary air location.
Ford Bronco ARB twin compressor installed with Grimm speed bracket sketch-1751602819410
Ford Bronco ARB twin compressor installed with Grimm speed bracket 20250704_000651
1979
Ben
Baltimore, MD
2023 Bronco Raptor
This looks really promising
rayofsi
Staten Island, NY
Raptor Gen2
Installed and working. Just need a bracket for my secondary air location . Confirmed arb twin will fit with an intake.
Ford Bronco ARB twin compressor installed with Grimm speed bracket 20250704_112755
Ninjak
Miami
@rayofsi : Looks good. A little ingenuity can go a long way. BTW, whose charge pipes are those? I know the BRaptor may not have as many choices as the 2.7 or 2.3 had.
rayofsi
Staten Island, NY
Raptor Gen2
Is that the brushless version or regular version?
Regular lol, had this sitting around for 2 years. Meant to take the single out of my f150 raptor for a double. The brushless one will work with some new holes being drilled.
