ARB Summit bumper installed 5/20/2024.
Michael541
Oregon
2018 BMW M2; 2015 Accord -goes when Bronco arrives
Ford Bronco ARB Summit bumper installed 5/20/2024. 20240520_195841
Ford Bronco ARB Summit bumper installed 5/20/2024. 20240520_195828
Ford Bronco ARB Summit bumper installed 5/20/2024. 20240520_195834
First off, Bronco6G was great for the decisions needed and made for this armor upgrade. Thank all the contributors on this forum that make informed upgrading easier.
I didn't perform the install, it exceeded my garage skills.
Winch - ComeUp seal slim 9.5
Suspension - 6112 Bilstein kit installed about 45 days ago for this Bumper install.
From info found on this forum, the shocks were set to clip 1 on the back and clip 6 on the front. This created 3/4" "pre-runner style" rake with the RC hidden winch w/factory capable bumper.
Measurements before final install measured from ground to bottom of the fender flares.
With Hidden winch
Front 40.2"
Rear 39.75"
Back to factory capable bumper and front skid
Front 40.75"
Rear 39.75"
After ARB installed
Front 39.75"
Rear 39.75"
Stoked to be level!
2Door weight with approximately 2/3 tank of gas indicated 5650 pounds. (Me in the seat 210lbs) - street driving load out. (No recovery gear).
Items that substantially add to weight.
Me :)
Frame mounted rock sliders
Steel transmission skid
Bilstein 6112's?
This new ARB
Let me know if you have any questions! Happy to try and answer.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
what was the stock height before the Bilstein install?
Michael541
Michael541
Oregon
How did it effect your adaptive cruise control and front mounted camera
I don't have adaptive cruise and I don't believe there is an ARB Summit bumper solution to account for it. Front camera is relocated and the very top of the flip up license plate holder is visible at bottom of the screen. 6-12" of viewing something last approaching is lost would be my guess?
Michael541
Michael541
Oregon
Yellow factory Bilsteins - If I remember correctly, rear was 39.5" and front was like 38.75 or 39.0".
Had a RC hidden winch installed and back was same, front went to 38.5" or a tenth or 2 lower.
This setup with Bilstein 6112's set for the future moved the back to 39.75" and the front on clip 6(max) was 40.5".
Lcubed
l
UsA
The summit bumper has a provision for the adaptive CC.
Did you start with a Sasquatch or regular Badlands?
Michael541
Michael541
Oregon
Cool, it wasn't included with my ARB bumper kit, is it a separate purchase? More curious at this point.
Yes, 23 Badlands SAS.
Silver-Bolt
Eureka, MT
The ARB kit comes with everything to relocate the ACC. I did it on my install. You also relocate the camera so it has a clear view.
Ford Bronco ARB Summit bumper installed 5/20/2024. PXL_20230908_222323263
Michael541
Michael541
Oregon
Yep, my camera is relocated. The ACC relocate portion of the kit didn't make itself noticeable, but it came up in discussion during installation. Plus, it isn't relevant for me so it was a brief topic during my install.
Searchdawg
Kentucky
2015 Supercrew Platinum 4x4
With Hidden winch
Front 40.2"
Rear 39.75"
Front 40.75"
Rear 39.75"
After ARB installed
Front 39.75"
Rear 39.75"
Stoked to be level!
Me :)
Bilstein 6112's?
This new ARB
Looks great! I have a 4 door ‘23 Badlands Sasquatch-2.7 high pkg. Purchased the Summit bumper and Warn Zeon 10S. Still sitting in my garage waiting for time and dry weather to do install. Currently have stock Sasquatch suspension, tires and wheels. Want to keep wheels and will upgrade to a different brand, but same size tire when the Territories wear out. Been debating about suspension to compensate for bumper/winch weight. Thinking Eibachs or 6112’s. Don’t want to break the bank and not looking to add 37s. Do you think suspension should be upgraded prior to install? Any issues with running stock suspension temporarily? Suggestions appreciated. Thanks! Again, yours looks sharp!
Michael541
Michael541
Oregon
Thanks! Long term, yes Suspension upgrade for sure. You're looking at 230-260lbs for the ARB with winch installed. This minus the 50-80lbs for just a stock capable or modular bumper for your net increase. The stock yellow Bilsteins are really only fine if you're never going to carry anything around in it.
I had a stop gap hidden winch, so I did the Suspension first, then only had 2 days of just factory weight for the ARB install. I don't think you can go wrong with either the Eibachs (non-reservoir) or the 6112s. As long as the shocks you choose are adjustable to keep the back as stock height as possible but fronts able to add preload to account for the added weight up front. Rest is down to timing and how much pre-runner style you can stomach until the ARB bumper is hung. Driving with about an inch of pre-runner rake for 45days was fine for me. No adverse handling on/offroad.
Searchdawg
Kentucky
Thanks for the feedback on the suspension. Guess I’ll be ponying up some more bucks 🤦🏻‍♂️. This site has been most helpful. I’ve lifted just about every truck I’ve ever had and installed winches on a few. How was your winch wired? Always wired the winches directly to the battery in the past. That was before upfitter switches (relay/switch) and knowing about the possibility of contacts melting down when lining in (Fix-battery isolator).
Michael541
Michael541
Oregon
Yes, this forum is great for brain picking!
Direct to the battery, new ComeUp seal slim 9.5. Most modern winches have built in thermal cuts for that contactor issue right? I have heard the same about melt downs, but I think modern issues are also more these days with cable (+) routing and chafing/shorting meltdowns?
Searchdawg
Kentucky
Good to know about the newer technology. I haven’t installed a winch since the 80’s so I’m a little out of the loop on improvements. Thanks!
breaddrink
Washington
Nissan's
I have ACC. It relocated and works flawlessly.
The camera placement sucks however. Misplaced AND in view of the license plate of you use the flip up kit.
If only they'd developed a bracket to locate it just a little out from its original mounting location, the badlands camera modes would still align...
I'll 3D print something eventually. I use my parking cams and so this really really bugs me.
