Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
lakesinai
Charleston SC
Im not sure what you did in the solonoid install that keeps you from shutting your hood because of contact with the air connector. The solenoid is necessary because the voltage to power the unit does not come from the switch but from the supply wire and therefore the switch wire simply shuts it on and off. At least that's my understanding. I agree that the lower bracket connection to the shock bolt is extremely difficult. By all accounts as you say the double ARB is much easier to install and the wiring harness works right without much interference or adaptation. I had four wheel parts to my wiring because I found it too complicated. I suggest that you rotate the unit in a different way so that it sits under your hood. See mine below.
Ford Bronco ARB Single Compressor Install Video (HELPFUL HINTS) SmartSelect_20230424_151813_Gallery
Ford Bronco ARB Single Compressor Install Video (HELPFUL HINTS) SmartSelect_20230424_152258_Gallery
Ford Bronco ARB Single Compressor Install Video (HELPFUL HINTS) 20230309_162409
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
I had it that way initially, but then I added the pressure switch. The pressure switch part of the harness didn't reach over to the other side, so I rotated the unit as far back as possible to plug in the red/blue pressure switch harness. I don't think it's hitting, but it's close.
I see you didn't install the pressure switch on your set up. If I redo the set up without the pressure switch, then I could rotate back. I was instructed I had to have pressure switch, but I guess not.
Thanks for the feedback.
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
I took your advice and switched it over. Much better set up, and no need to adjust every time.
Ford Bronco ARB Single Compressor Install Video (HELPFUL HINTS) 20230425_113844[1]
lakesinai
Charleston SC
Excellent! My pressure switch/solonoid is on the other side, out of view! I installed the unit and bracket, 4wp installed the solenoids and wiring. I've done my own boat wiring for years, but I could not understand the instructions for how to wire this, and using the upfitter switches. Paying someone else to do the wiring? Priceless! I admire your ability to do that yourself!
Sozzy1269
Southern Idaho
23 Bronco 2door, 2012 Raptor, 2017 f350
Sorry for resurrecting an older thread... I'm going to be installing this compressor on my bronco and have a couple questions.
What mount are you using? Did it come with the compressor?
Got a link if not?
Thanks
Sozzy1269
Southern Idaho
Sozzy1269
Southern Idaho
cr117
PNW
Bronco, EV6
Good deal. Anyone know if there are any cheaper options? $250 seems like a lot for what it is. The ARB mount is $260...
If you're strictly talking about engine bay mounts, from what I've found, they're all pretty similarly priced. Here are the common ones you'll see posted about frequently on here:
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Got a link if not?
Thanks
He's using the KR Off-Road Compressor Kit (on sale this week!): https://www.4x4truckleds.com/kr-off-road-air-compressor-engine-bay-kit-for-2021-ford-bronco/
I would recommend the twin compressor. Installation is MUCH easier and the compressor is MUCH faster. However the single WILL save you some cash.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well the KR Off-Road one is made here in the USA out of stainless steel with a lifetime warranty. At $249.99 I believe we're actually lower then some other kits AND we're the EASIEST to install (which is why we have a patent pending design). Other compressor mounts do the job but require a LOT more work to make happen.
Our kits are on sale this week also (Labor Day) so you save 15% once you add the kit to your cart. That's some big savings, especially when you add in a compressor (which also gets discounted)
Sozzy1269
Southern Idaho
Ordered my mount from you a couple days ago... Still seems like a lot for a mount. Already got the single compressor from ARB.
