Theherofails
Thomas
Phoenix
Found a home for the 1 gallon air tank, was hoping for a vertical mount for draining water from the tank, there's a nice protected spot in front of the gas tank for a horizonal installation. See post two in this thread. Haven't found a good space for a second tank. There's room where @Theherofails installed his compressor, but I'm not going to drill holes in the floor pan. Plus to even get the tank in there one would have to jack the body up to unload the rear axle to slide it in place. Not going proceed with a second tank for now.
Did you look at the rear frame off to the side opposite the gas tank? Lots of room over there If I remember, also right behind the gas tank also has a bit of frame exposed you can likely drill into for bolts. You should have plenty of clearance from the bits moving around, like the rear diff. Its quite roomy under there.
The exhaust runs opposite of the gas tank, but Ive seen the spacing vary quite a bit on Bronco examples I've looked under. Some have the exhaust practically touching the frame so it may rule it out. Im not convinced that exhaust hanger is welded in the same place for all trims.
Love the mount idea. Props, my man!
nminus1
Henry
High Desert So Cal
Chevy Duramax, Trailblazer, and Ford Escape
$129.
https://www.summitracing.com/parts/...ltHzDZ28FahnkhQ_TLguFZ8PqOq3_SvBoCUxYQAvD_BwE
Fills your tires, your friends tires, air rafts, air matresses, hell even footballs or soccer balls. 12/20/120 volt. Runs off its own battery, your car battery or plug in. Set the pressure via digital control, it stops when it hits that pressure. Set it and forget it. Best tool I ever bought. Weigh 5 pounds and totally portable. Just saying....
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment det-dcc020ib_xl
Parker
PA / CA /AZ
Gr Che Overland, Corvette, Tahoe, 46 Chevy 2ton
Nice job. That engine compartment is as ugly a any Jimmy Carter Malaise Era car. I am waiting for a clean-up there and allowing BesTop from factory without buying any of Fords useless tops - and a two month order turnaround - it will happen.
Ingridthehorrible
Ingridthehorrible
FL
2005 Chevy 2500HD, 2008 Buell 1125R, 98 Buell S1W
Yeah, looked at those areas, in front of the gas tank was the most protected area, if I decided to proceed with the second tank it will have to go up into the area where you mounted your compressor. Believe I can build a mount to hang a tank in that area since the tank doesn't have weight the compressor does. As to drilling holes in the frame that is something that I'll never do, have seen cracks start from holes drills into the frames, where I mounted the one tank used an existing hole.
Ingridthehorrible
Ingridthehorrible
FL
Yeah. My Bronco isn't a daily driver.. it's a toy, really. I work at home, as much as you can call it work. I'm lucky in that regard. I'm building a slide out tailgate and mount for an overland fridge and at some point my air compressor controls will be moved up into the cargo area near my power control station and second battery. I haven't had my back seats up since I got this thing and will potentially remove them.
With all that said, redundancy is paramount in overlanding and off roading in general. You'll do great with just a tank. They do take up a lot of room but that's more an issue for over Landing.
For the guys worried about 4 holes in the floor, you're gonna LOVE what I have coming up. 🤣
It will be interesting to see what you build for a slide out tailgate. I'm planning to do a slide out drawer with a slide out shelf over the drawer with a fridge mount, hoping to build something that will still allow access to the under floor storage. But that project is for next year.
Theherofails
Thomas
Phoenix
Oh judging by the
Its gonna be tight, but I want aux power on the left and secondary fridge on right with storage in the middle. Im waiting on an overland trailer to be built to know for sure how i do the cargo area.
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Professional sports. Baseball, basketball, football...
But not hockey. Hockey rules and is the best.
Additional note... I like the Bronco Sport for what it is. I don't understand the shit-talk. Reminds me of my 2010 Escape, but more capable. ¯\_(ツ)_/¯
I agree. It’s a great car all around and can fit 2 mountain bikes in the back!
Boston182
Matt
San Francisco, California
Harley Davidson Sportster
Agreed. Hockey for the win. Going to the Stars game tomorrow!
Judging from your user name you’re more of a Bruins fan, but at least we can agree that hockey is king of sports!
Worse. Blue Jackets fan. Hate the goddamn Bruins. Marchand can eat my ass.
From Ohio and never stepped foot in Boston, ironically. Just my name. ¯\_(ツ)_/¯
Chaos_273
GMC Sierra
Whew, almost had me triggered seeing “blue” and thinking St. Louis. 😂
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
Update # 2. Have mounted the 1 gallon air storage tank that will be connected to the compressor for air storage and also mounted the air line quick disconnect on the trailer hitch where it is protected and easy to access. Still need to order airline and fittings to complete installation Plan to installed the electrical tomorrow. Most likely next weekend for the air line installation. Pictures follow for air tank and quick disconnect.
Space for 1 gallon ARB air storage tank in front of the gas tank
Bracket built for tank installation
Tank with bracket installed
Tank installed
Clearance between air and gas tank
Clearance above tank
Trailer hitch before quick disconnect installation
Air line disconnect and bracket that was fabricated
Air line quick disconnect mounted on trailer hitch, will be making a dust cover for quick disconnect.
Update #1. Removed the bracket so I can de-burred the cut edges, then cleaned up and paint. Also insured the air filter access wasn't impeded. Here's some additional pic of the bracket
Mount in Vehicle without compressor install
Mount out of bronco
Mounting bracket attachment points to Bronco
This gets the Rednek seal of approval,my motto others scraps = my next project
Hossfire
Ken
Richmond, VA
'06 Jeep Commander
$129.
This is my kind of solution. I do like the spare air tank though "just in case".
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
$129.
Does this struggle with SAS tires?
nminus1
Henry
High Desert So Cal
They are just tires. It goes to 120 PSI I dont see why it works for me on everything I ask it to.
ASlaugh
Andrew
El Dorado Hills, CA
65 Mustang, 21 Bronco Badlands
I’ll just wait until Powertank comes out with their Bronco rollbar mount, no loss of floor space, drilling or wiring and can leave the tank at home when not needed and can also move it from vehicle to vehicle. Used about every hard mounted air compressor available over the years and the Powertank handles 90% of what I’ve needed from filling up tires, running air tools, air mattresses, only downside is risk of it running empty so I always refill when it gets to <30%.
Not a good idea people. Just 1 lb of CO2 leaked into the vehicle can make you pass out or die from asphyxiation. There is no warning either as CO2 does not have an odor. These cylinders are meant to be mounted in open air vehicles only, or outside of the cab.
Now, mounting a compressed air tank on the roll bars would be just fine.
