Anyone using S&B CAI with Procal 2.7?
23OBX2.7
AB Canada
2023 Bronco
feedback pls
JL8jeff
Ewing, NJ
Is the S&B even available for the 2.7 yet? When I was looking, it was always out of stock. I ended up getting the CVF intake and run that with the Mishimoto intercooler and charge pipes along with the Procal.
23OBX2.7
AB Canada
2023 Bronco
yes. tangible venefits with yoir cpmbo and procal?
JL8jeff
Ewing, NJ
It's tough to say. I did the Procal and Mishimoto stuff at the same time and already had a Corsa airbox with a larger filter. So switching to the CVF over the Corsa wasn't as noticeable as it probably would have been from the stock airbox. The stock filter is 3.5" diameter and even the Corsa setup is over 4" and most of the intakes are much larger than that so they can flow a lot more air. If you can find an intake under $300 (look for discount codes or slightly used on FB or Ebay) then I think it's a no brainer, especially when you combine it with other mods.
23OBX2.7
AB Canada
2023 Bronco
Thks since now have procal and can gey S&B dry locally Im contemplatong it still.seems a bit sluggish off the line in sport mode and on highway WOT for 400 ft lb +
JL8jeff
Ewing, NJ
Still sluggish with the Procal? Mine jumps pretty good in normal mode with it, I don't use sport, it's too jumpy. I also added a GPE ported throttle body and that helped the throttle response for sure.
Sasquatch2ez
NY
Badlands, 2.7 Sasquatch
Following as I have a S&B coming for 2.7
SHANUT
Craig
Hermann, MO
I have the tune, but I’m surprised that yours feels sluggish. If I so much as breathe on my throttle pedal, the front end raises a couple of inches. If I could maintain traction, my bronco feels like it would easily lift the front end off the ground. It’s a two door so that probably makes a little difference but not much.
Sasquatch2ez
NY
I ordered a cold air intake from them 2 months ago and still nothing. I’m wondering if they’re ever going to ship
Does the order say “preparing for shipment?”
23OBX2.7
AB Canada
2023 Bronco
I called my trusted Ford Performance and other performance parts vendor yesterday they told me the S&B dry filter or complete CAI won't ship until end of month from S&B. I can get oiled in a few days but don't want it.
I'm just gonna pass on this the benefit is likely marginal to nil, install looks easy but a pain, and I don't want to spend money with any company that's doesn't have stock when my wallet is open haha.....please stop blaming the Chinese for poor business performance LOL
Will pick up a wix today.
23OBX2.7
AB Canada
2023 Bronco
WIX is great noticed a difference from relatively clean 1 year old Ford filter.
CrankAddictRich
Rich
New Jersey
2024 Bronco WildTrak
I'm running the S&B with Pro-cal tune, Full-race intercooler and Turbosmart BOV.
The biggest difference maker was obviously the tune... it will be hard to argue that. but I definitely feel that the intake made a difference.
JL8jeff
Ewing, NJ
I saw this S&B for the 2.7 pop up locally for sale on FB Marketplace. So I guess they are out there. The main thing I don't like about it is that it doesn't replace the restrictive elbow on the passenger side turbo like some of the others do.
Marketplace - S&B Bronco 2.7 intake with NEW filter | Facebook
