Anyone Try limiting straps?
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
Anyone Try limiting straps to keep down travel in check?
I'm going to experiment but I need to know what length to try first.
akturbo
Seattle Eastside
What shocks? What problem are you trying to fix?
PWillette
Parrie
Maine
I presume he's trying to limit droop up front.
NorthShoreBronco
NorthShoreBronco
Steph
Canada
www.youtube.com
Correct. I have a 5 inch lift. I need the clearence but don't care about flex as much for snow wheeling. and cv shafts are getting expensive.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Straps don't work how you think, you will be fighting brackets and mounting. You have to much going on in the limited space and aluminum lower control arms that you can't weld to.
Sounds like you need to try a different combination of spacer and strut. You should have someone cut down those massive spacers and reweld them. An exhaust shop would probably charge you 1-2 hours labor.
NorthShoreBronco
NorthShoreBronco
Steph
Canada
www.youtube.com
I'm actually taking those out and putting Vertex Coil overs in. same height, but I am hoping that the stiffer suspension will limit the droop a bit... or at least not make it as violent.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Toyota guys are using lower control arms skid plates as mounts. I still think it would be cheaper to have someone take the shock apart and put an internal bump stop in.
FYI I would stick to modifying the bracket and buying a normal front coilover. Cheapest, easiest and reliable solution to your issue.
Ford Bronco Anyone Try limiting straps? IMG_2065_abbaee0487cd61157143455d6007e62ad542bcab
NorthShoreBronco
NorthShoreBronco
Steph
Canada
www.youtube.com
Well.... I have these sitting in my garage already so...... In retrospect, I should of ordered the 3.5 maybe to drop it down a bit... but here we are.
Ford Bronco Anyone Try limiting straps? 1724871880807-m
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
Other than those coilovers, do you have anything else added to the shocks to add length? Top hat spacers or something like that? Are you running drop bracket kit of some sort?
