- Banned
I've seen a few rigs with RTR wheels in +30 offset. I'm wondering if anyone is running the Rtr wheels with 0 offset. Pictures greatly appreciated
Do you have Sasquatch? The +0 are designed for Sasquatch package...offset is the same. Unless you want to run +0 on a standard Badlands and have them stick out another inch.I've seen a few rigs with RTR wheels in +30 offset. I'm wondering if anyone is running the Rtr wheels with 0 offset. Pictures greatly appreciated
Correct, assuming you want 17inch wheels.I was interested in RTR's as well. I am going to have sasquatch package. I should be looking at the 17x9 +0 offset, correct?
I have a Black Diamond running +30s...they poke out a little bit past the fender. If you go +0 you're adding 1.18 inches further. unless you change the fender flares I though you're going to be poking out like 1.5" which is a lot to me. If you change fender flares though, you're basically a non-Sasquatched Sasquatch.I order a nonsas. But will be adding 2"-3" lift and running 315/70r/17. I like a little poke but nothing insane .
Badlands are 55 offset, Squatch is 30. 0 offset rims will make the tire stick out further approx 2 inches on Badlands and approx 1 inch on SquatchDo you have Sasquatch? The +0 are designed for Sasquatch package...offset is the same. Unless you want to run +0 on a standard Badlands and have them stick out another inch.
do you have a picture facing down the side of your bronco to show poke If someone was behind you ?I have a Black Diamond running +30s...they poke out a little bit past the fender. If you go +0 you're adding 1.18 inches further. unless you change the fender flares I though you're going to be poking out like 1.5" which is a lot to me. If you change fender flares though, you're basically a non-Sasquatched Sasquatch.
https://www.bronco6g.com/forum/threads/bye-bye-steelies-hello-rtr-wheels-on-my-2021-bronco.18735/do you have a picture facing down the side of your bronco to show poke If someone was behind you ?
Ahh, thank you. For some reason I was thinking Squatch was +0. So I stand corrected.Badlands are 55 offset, Squatch is 30. 0 offset rims will make the tire stick out further approx 2 inches on Badlands and approx 1 inch on Squatch
