Anyone offroading with an extended hitch?
SunilD
San Diego, CA
2024 Bronco Wildtrak
I recommend a regular hitch and the Kuat Pivot. The pivot provides enough clearance for the spare tire, and has the added bonus of swinging/pivoting the bike rack out of the way so you can open your tailgate.
It's easy enough to remove when you go wheeling, doesn't rattle.
How much effort IE time does it take to install? I have to loosen or remove he bumper to install this hitch.
The receiver is just the square box the hitch hooks into - I leave that in - unhooking it would be 4 bolts and may or may not need your rear bumper dropped depending on your bumper.
The hitch is just the bar with the ball on it. It usually just attaches via a hitch pin that is a quick release, sometimes they have a lock on them.
So to pull the hitch off is just pulling the pin, maybe with a key.
Jdyount
Jason
Kansas
2021 Badlands
superchar1982
Charlene
west sacramento
2024 2dr bronco 7spd , 2022 911
This is my setup as well. Curt hitch, kuat pivot v2 and 1up HD. Nice to be able to open the tailgate when you have bikes loaded.
SmallCrawler
2023 2dr Bronco
Couldn't fit my anti-rattle plate for my Bodyarmor skid since Ford jams all the wiring too close to the hitch. So I got this aluminum gizmo off of Amazon. Plenty of departure angle on a 2 door Sasquatch so it didn't get scraped on my most recent trip.
Ford Bronco Anyone offroading with an extended hitch? IMG_1889
vrtical
Doug AI
GSMNP, TN
Fords
I have this on all the time for my bike rack which clears my spare, have it in raise position never any issues.
Ford Bronco Anyone offroading with an extended hitch? 1759159804727-o5
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
I use the standard short receiver with the Kuat Hi-Lo extender. The extender has an internal cam you rotate to keep from rattling. There is no rattle.
https://kuat.com/products/hi-lo
the downside of the extender, vs the Kuat Pivot, is the rear hatch cannot open when the rack is installed. But that’s not an issue with me as I mostly transport my bike to a trailhead and ride. I don’t use the bike rack for extended trips.
I have forgotten to remove the extender while wheeling. And yes you can get yourself into a bit of a bind if going up a slope/rock as it can prevent you from backing up to re-position.
I would not wheel (aside from fire roads) with a loaded bike rack + extender. That’s a lot of force with two bikes bouncing around. Unless you reinforce the hitch. One member has done that @TeocaliMG
I haven’t been rear ended yet with the extender. I was wondering if it would be a help or a hindrance. Sounds like more of a hindrance
Hammerli22
Isuzu Rodeo
I have a bike mount that attaches to the spare tire, it worked well on my Isuzu rodeo 4x4. It came with a extra mounting hardware that allows for different wheel lug patterns, unfortunately I couldn't use it because the bronco has a rear view camera. I paid $50 on craigslist for this and I didn't want to buy another bike mount, so I took out the plasma torch and welder went to work. I don't think Ii could carry an electric bike without a tailgate reinforcement.
Ford Bronco Anyone offroading with an extended hitch? Screenshot_20250929_180740_Gallery
Ford Bronco Anyone offroading with an extended hitch? 20250403_174901
Ford Bronco Anyone offroading with an extended hitch? 20250403_182811
Ford Bronco Anyone offroading with an extended hitch? 20250403_174857
Ford Bronco Anyone offroading with an extended hitch? 20250403_182735
Ford Bronco Anyone offroading with an extended hitch? 20250310_163855
Ford Bronco Anyone offroading with an extended hitch? 20250322_120106
diamonddawg21
diamonddawg21
Wylie, TX
2024 Ford Bronco Wildtrak
Lots of great feedback and ideas, and I appreciate everyone for taking a moment to assist. I am going with the standard short receiver and will try with no spare and with an extender and spare. The long receiver just screams PITA for offroading as we frequent OHV off-road park in bridgeport TX, a lot. I will keep you posted as parts are arriving later this week.
the poacher
john
Whistler
2010 ford ranger
Hey OP,
I do extensive mtn biking and I have also tried to run bike racks off of the hitch with an extender and I can tell you that whether it is a vertical or horizontal rack, it will not work. You will drag the rack or the tires of your bike on the ground, unless you are 4 wheeling some basic trails.
But, if you are doing any type of technical trails to get to some good trail heads, the only way it will work is with a rear tire delete (which I now have) and a vertical rack that angles upwards. Such as the Thule Vert rack. Any horizontal rack will really limit your departure angles.
Living in the Whistler area, we have some great shuttle routes, but they require some aggressive wheeling to get to the trail heads, and horizontals get hung up all the time.
Good luck on finding your right solution...
diamonddawg21
diamonddawg21
Wylie, TX
Do you have a link to this or the mfg name?
