Anyone have experience with M&R Light Bars ?
Kmautah
Kevin
F-150 Lariat, Tesla Model 3, MB Sprinter Van (170)
I have the amber lights on AUX5 and I just leave it on. The led portion of it is on AUX2. The M&R ditch lights are wired similar, amber on AUX6 and led AUX3. The AUX switches turn on and off with the Bronco so with the AUX switch in the on position they technically come on when I start up. Hope that makes sense!
I just bought this M&R light bar, prob. will install tonight. I have the Aux switches, but have not wired anything to them yet. Sorry for the rookie question - but if the Amber DRL is on all the time, is it necessary to use an Aux switch for that (which just stays flipped on 24/7). is there another method to provide the DRL power without using up an aux switch?
CBass
C
Pflugerville, Texas
2024 Ford Bronco/2024 Toyota Sequoia Platinum
I am sure there might be something you could tap into for the Amber lights to be on all the time, haven’t really thought about it. If you don’t want to take up an aux switch you could always run a separate rocker switch to the Amber portion as well and mount it on the big plastic piece under the steering wheel. If you decide to tap into something just be sure you get all your volts/amps figured out so you don’t overload a circuit.
MandRautomotive
Mikhail
CA
Thank you all for your support!! You can use coupon code COLBY10 to get 10% off of your purchase at checkout.
2021+ Ford Bronco M&R Light Bar Kits
Check out this quick installation video to see how easy it is to install our kits yourself. Have a great Sunday everyone!
Maryland
2025 Ford Bronco
I think I am going to pull the trigger on this M&R light bar. Just can't decide whether I want the amber backlight on all the time or to only come on with the headlights. I know I can wire both the white and amber to a switch but I think I might rather it only come on when the parking lights come on. Not sure I need the amber lights on during the day. What did others do?
BillTheCat
Alaska
4Runner; Bronco: BB/SAS/LUX/2DR
If you have the UpFitters, just use two diff switches for DRL/Main.
-You decide
-Eazy Peazy…
Maryland
2025 Ford Bronco
-You decide
-Eazy Peazy…
Right but then I'd have to switch on the ambers.... I'd rather they come on automatically with the headlights and stay off during the day without having to use a switch at all.
psdtime
Tom
CA
2026 Bronco
Did you ever get this? Wanted to know what your thoughts were on it.
psdtime
Tom
CA
2026 Bronco
Installed the PRO 30" over the weekend. These light bars are better than they should be for the money! I love how it doesn't extend past the bumper.
Ford Bronco Anyone have experience with M&R Light Bars ? 1780935010659-ah
Ford Bronco Anyone have experience with M&R Light Bars ? 1780935025201-tu
Ford Bronco Anyone have experience with M&R Light Bars ? 1780935038138-9f
Ford Bronco Anyone have experience with M&R Light Bars ? 1780935173546-qn
Maryland
2025 Ford Bronco
I did... i think it's great. THe fit was very tight between in the space above the bumper and getting the brackets installed wasn't the most fun but it wasn't horrible. Ambers look awesome and the white lights are super bright. Very impressed. I wired both to my aux switches.
Ford Bronco Anyone have experience with M&R Light Bars ? IMG_5525
Ford Bronco Anyone have experience with M&R Light Bars ? IMG_5529
Kiddo44pct
NY
Chevy traverse
Quite possibly the best customer service ever..had few LEDs go out and was immediately sent a new light bar by Mike.
They really stand behind the product..also will add that this is definitely the best light bar for capable bumper...super bright
MandRautomotive
Mikhail
CA
Thank you for the kind words. Glad to be of service! Hit us up anytime with questions.
