Anyone have experience with M&R Light Bars ?
RedWhite&Blue
Greg
New Jersey
2023 Bronco
I bought one about a year and a half ago and no issues to date. I went with the amber backlight version which I keep lit all of the time. It was also a pretty easy install - having run power through the aux switches.
Nickyweg
Nickyweg
Cleveland
2020 Mustang Gt
Is it as easy as it looks?
Mount bar
Connect positive to brown/green for Aux 2 with a crimper
Ground negative to body with a bolt
Done
CarGuy
New Jersey
2023 Ford Bronco
I bought the 40” early summer - amber driving light and super bright white light. Bolted to the bumper with no issues and very easy to wire to aux switches. Very pleased with purchase.
Ford Bronco Anyone have experience with M&R Light Bars ? IMG_2144
Ford Bronco Anyone have experience with M&R Light Bars ? IMG_2145
Ford Bronco Anyone have experience with M&R Light Bars ? IMG_2146
Nickyweg
Nickyweg
Cleveland
2020 Mustang Gt
I bought the 40” early summer -amber driving light and super bright white light. Bolted to the bumper wi no issues and very easy to wire to aux switches. Very please with purchase.
Is the process truly as easy as I listed above ?
CarGuy
New Jersey
2023 Ford Bronco
Yes. I did 2 aux switches given two light colors. I used aux1 for the white and 6 for amber. I soldered all my wiring. , but crimp will work.
RedWhite&Blue
Greg
New Jersey
2023 Bronco
I did the same with 2 aux switches.. Yes - it was that easy to install..
22 Spyder
Fort Lauderdale
2024 Azure Bronco Raptor (DD),2022 Porsche 718 Spyder(weekend)
I will be going with the M&R 40" curved 24,024 lumens and window cubes with amber backlighting when the time comes. They look to be good bang for the buck over something like Rigid etc.
BillTheCat
Alaska
4Runner; Bronco: BB/SAS/LUX/2DR
Only had mine for ~a month. So far very happy with it. I keep the DRLs on most of the time and the whites are sufficiently blinding. Install was super easy as the rest have stated.
I crimped on Male/Female blade connectors so I can easily switch to different aux upfitters if I want to later. Mike, the owner is awesome and eager to help with any issues. Which there were none. Eazy Peazy.
https://www.bronco6g.com/forum/threads/extra-lighting-that-doesn’t-cause-a-ton-of-wind-noise.102290/post-2356214
ChrisZ
Washington
I bought one a year ago. One of the best upgrades on the Bronco. Not to hard to install if you have small hands.
I was considering upgrading my bumper however don't want to have to remove the light bar with an aftermarket bumper.
helifino16
Ron
Mount Sinai, NY (Long Island)
Mount bar
Done
Yes, it's that easy. I only have white, so I was able to use Aux 3. Only tricky part was hiding the wire behind the grill.
Ford Bronco Anyone have experience with M&R Light Bars ? Blue Lights On
Nickyweg
Nickyweg
Cleveland
2020 Mustang Gt
How hard was hiding the wire ?
helifino16
Ron
How’d you hide it?
I can't remember exactly, but I'm almost sure that I ran it alongside of the Radiator with a couple of zip-ties.
ChrisZ
Washington
Wiring was pretty easy up next to the battery to the uplifter switch wire on the drivers side. The wire was long enough. I used the second switch with the higher amp
rating.
The install video is helpful.
