Anyone have a fix for squeaky window?
ColoradoSkiDreaming
Nashville
My front widows squeak really bad when it rains (when you raise or lower them)…. It’s really loud and totally annoying and embarrassing. Not that I’m lowering them a bunch in rain but it still shouldn’t happen on a car in this price range. Any advice appreciated.
MyATV
ATL
If it's from the rubber...
Ford Bronco Anyone have a fix for squeaky window? 1702218854852
Shane78
Shane
St. Louis
2D
Buy some krytox 204 or 205 and apply it sparingly along the rubber that the window seats into and then smear it all over with a finger. Barely any and Itll take care of the squeak. It also works for the seal rubbing against the back window if you have that.
Krytox GPL 205 Grease, Keyboard Switch Grease , Pure PFPE/PTFE, 0.5 oz Tube https://a.co/d/grgMvY6
Area51BS
Ron
Badlands non SAS 4dr 2.3
Yes. This. Apply when it squeaks until needed again. Stopped mine immediately and no greasy residue if you apply just enough. Haven’t experimented with their ceramic on window seals yet except on tires which is awesome.
https://www.griotsgarage.com/vinyl-rubber-dressing/
MyATV
ATL
You know that tube of K-Y you brought with you to the dealership the day you picked it up? The answer lies somewhere in there.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! I can look into your Bronco's window concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
gavg91
G
Maryland
'23 Bronco Base Sasquatch
hey bud what did you end up doing? Mine started the squeak this morning, after a rain overnight, came back a couple hours later and nothing lol
screwly
houston
23 bronco raptor
Bumping this because mine is doing the same thing… is the vinyl rubber dressing the fix?
CitrusBronco
Everglades
Citrus county, FL
Everglades
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
Same here only squeaky when wet. I’m looking at getting some dressing for the top seals and will try it on the door window also. Not sure where you apply it for the window, seems it would be inside in the track that squeak’s 🤷‍♂️
I’ve been recommended this 303 for the seals on the top . https://www.amazon.com/303-Rubber-P...hvlocphy=&hvtargid=pla-4584001419021944&psc=1
Do some digging on the forum, I had the same issue and found a thread where they discussed an extra seal which I did and it fixed it. Everyone that tried the lube said it worked at first then stopped after a couple weeks. I did this early Feb and it still works great no squeak. I looked real quick for the thread but couldn't find it but here's the seal. It goes on the inside top of the tailgate making the connection point tighter.
Amazon.com: 33Ft Universal Self Adhesive Weather Seal Strip for Car, 51/100 Inch Wide X 1/5 Inch Thick, Auto Door & Window Weatherstrip with Engine Cover (2 Rolls, 16.5 Ft Each) : Automotive
