Anyone else accidentally turning on headlights?
Az_Squatch_Bronco
Shawn
Tucson
Bronco Badlands w/ sasquatch pkg - Carbonized Grey
I am 5ft 10 and have not had this happen, my seat is almost all the way back. My left leg goes out first, I am assuming folks are hitting it with the left knee??
I couldn't do it with the way my seat is now. I would have to be belly up to the steering wheel!
Ford Bronco Anyone else accidentally turning on headlights? 20230830_124346
Ford Bronco Anyone else accidentally turning on headlights? 20230830_124354
Ford Bronco Anyone else accidentally turning on headlights? 20230830_124401
Az_Squatch_Bronco
Shawn
Tucson
You should already be aware this is a known issue. Just a Bot, I guess?
Its not a bot...I dont know how known or common this is.
Mjtermini
2022 2DR Badlands
Be that as it may, that is a separate issue. Hitting the knob with you knee is a real thing that many of us have (obviously) experienced…
Yep, me too
Jruta
Nj
A51 Bronco 2 door
Yeah this was happening on my 22 since the day I picked it up (random headlights turned on) and thought I was doing something wrong. Nope. Problem with the logic board. Unfortunately I don’t have the service bulletin number anymore, but you can probably find it on this board.
Az_Squatch_Bronco
Shawn
Tucson
So far the Bronco has been flawless for 1500 miles.
AKBronc49
Russ
Anchorage, Alaska
Almost 2 years and never had this happen, but I'm only 5'10".
tock13
Tony
WA State
Ok, here’s a opportunity for one of our vendors here. Need something like this in hard plastic to cover the switch. Most put the light switch on auto and leave it. Flip the cover on, instant knock bloker.
Ford Bronco Anyone else accidentally turning on headlights? IMG_8722
Docdon
Don
Parker, CO
jeep
It happened more when I first got it. My knee is the usual culprit. I pay more attention and it happens a lot less now 10 months later.
helifino16
Ron
Mount Sinai, NY (Long Island)
I've found that if I avoid touching this switch, my lights tend to work as expected.
Ford Bronco Anyone else accidentally turning on headlights? 1693491296373
frdfan
Greg
LaVista Nebraska
22 BB Sasquatch HPRM
Hit it all the time in my F150, haven't hit it yet in the Bronco.
D Rock
Dan
Hartland, MI
2022 Bronco Big Bend 2-Door, Cyber Orange
I'm only 5'9" and have done this many times.
ibock
Dallas
2022 2 Door Bronco
I went to Ford and they did a software update and it has not happened since. It's only been a little over a week though
Stache12
Wisconsin
Ford Explorer, Chevy Cruze
Yes, Ford design flaw. I just check the knob every time I exit the Bronc. Just added to the to-do-list after I park it, turn off the ignition, put in second gear, pull up the e-brake, etc. You get the picture. Some define me as anal, or whatever disorder term is currently used to describe this behavior by the medical community today. I define it as normal which use to mean responsible back in the day. Tommy Bronc
not really a ford thing, numerous GM vehicles have the same knob style in the same location. I've done it in multiple vehicles.
