Alternator stopped working (5,000 miles)
Tadel001
Tim
Maryland
‘87 Defender 110 RHD
Drove my Badlands 2.7 mid package tonight. Got a warning that my charging system needed service and I wasn’t getting a charge. The alternator came back on. Then stopped again - same thing happened and it came back on. Third drive, the alternator never started working. Curious if anyone has had a similar issue or knows of some Ford alternator quirk. Really upset because I need the Bronco to drive to NY and then Pittsburg for Thanksgiving.
BroncoBuckaroo
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
sorry ..that sucks are you looking at the gauge to know if Alt isnt working?
in the old days a quick test would have been To get the vehicle running and disconnect a battery cable real quick and see if the engine stayed running. If so Alternator was probably ok.
Tadel001
Tadel001
Tim
Maryland
Yes, gauge says 12.2V. Should be 13.9 to 14s. When it came back on, it jumped from 12.2V to 13.9. On the Bronco Sport forum there was a similar issue. Seems the alternator connector corroded. I did take it off roading and the bottom half of the engine bay did get wet from splashing. Assuming a corroded connector… guess the Badlands bronco can’t get wet?? That is going to be a big problem.
BroncoBuckaroo
Missouri
ugh ...that would be some quick corrosion
Macjr
Martin
Northern NY
Toyota Tacoma TRD Offroad, 2020 Volvo xc40 RDesign
Seems like quite a few gremlins with the 2.7’s lately
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Correct me if I'm wrong, but wasn't there concern of the alternator's location on the 2.7? Seems like last year, people had mentioned that it was mounted low and would be a concern.
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Maybe I am wrong, but wouldn't this also likely apply to the 2.3 location as well? Not saying OP is correct they caused it but it's concerning regardless.
THEMANatwar
Bossier City, LA
1993 F150 Flareside, 2022 Bronco Badlands
Dumb question...your battery terminals are tight? I saw another thread where they weren't, and obviously that would put extra load on the alternator if it was disconnected/poorly connected.
Yeah might check the wires connecting to the fuse block in the bay as well. I've heard the ground wire can be loose and cause charging issues.
Theherofails
Thomas
Phoenix
Starter is what I usually see people complain about. Its on the bottom of the engine which is normal for Ford Ecoboosts. It's also vulnerable to water ingress. I had a 3-4 day period where I had to hit the start button 2-3 times to start the Bronco. I took about an hour long drive and it dried right out though.
The issue isnt the location of the starter though. Not exactly. I was stuck in quicksand with the bottom of my truck submerged for 6 hours and it started right up after. The issue is water shorting the positive terminal and shunting your power to ground so the vehicle wont turn over first try.
Beach_Bum
St. Augustine, FL
I can't recall exactly. Maybe it was the starter. I just know that it was a point of discussion in the fall last year when we had nothing else to bitch about discuss. I, of course, have no point of reference other than relying on my poor recollection as I continue to wait for a Bronco.
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
What did the dealership say?
Tadel001
Tadel001
Tim
Maryland
Having it towed to the dealer today for service tomorrow.
