Alternator relocation
JasonNEK
Jason
Saint Johnsbury Vermont
F150 and badlands.
It really seems as if my badlands could go anywhere. Until mud and water killed my alternator. Now I’m afraid to go out until I can get a relocation kit. I don’t want to have to buy an alternator every time I go out. This problem will keep a lot of people of the trails.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Should be replaced under Warranty, there is a Ford TSB covering it, there is a shroud specifically to cover the alternator to keep it from getting fried. Do a quick search and you'll find a whole thread on it, including the TSB number.
PSUTE
Western Maryland
Sierra
Shop around the forum. Their is a TSB for alternator replacement when mud filled...
Combustion_King
Derek
MA
Yes
seems like you need to get over the bad one time, things go... its an offroader.
da_jokker
Jeep Wrangler JKUR
The 2.3 is higher, but by what? A couple inches.
Unless the 2.3 is a totally different built/designed alternator, that's not going to be your saving grace.
AK007
Washington DC
Awaiting my Bronco
IAG is working on an alternator relocation kit last I heard a few months ago for the Bronco
MNBigfoot
MN
Precisely, the alternator on the 2.3 is at the bottom of the engine, well below the "safe fording depth".
br.jonathan
Jonathan
Puerto Rico
Currently in my third alternator rotation. Have the original and a second to swap in these situations
1st original alternator original cover
2nd new alternator installed with revised cover
3rd original alternator cleaned (currently installed and working)
See picture this had the revised cover…
I want an Australian sealed alternator for the Bronco…..
Ford Bronco Alternator relocation 5bdd1b6a-68f7-4de3-b9aa-040d887f9689
_Moar_
Nosara, Costa Rica
I just called IAG to get an update on when they are going to release the alternator relocator kit... and they said they stopped the project because there was a patent pending. I asked if Ford was the one who applied for the patent and she didn't know. 😢
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
ScLeCo
Springfield
Charger Hellcat
If it is Ford then they know they fucked up and they better give the previous generation owners the revised set up. (which ha ha of course they wont)
