Alpines installed!
Peepers
Stacey
TN
2024 Bronco
Installed some new speakers and what a difference it makes. I don't have the B&O system but do have the 7 speaker factory setup. I installed S2-S40's in the dash and rear pods. It's probably the easiest install I've done to upgrade speakers. Less than 30 minutes total time.
Question for the audio experts. Would just replacing the sub make much of a difference or would it be better to just replace it and add an amp?
Ford Bronco Alpines installed! 20240408_140555
Ford Bronco Alpines installed! 20240408_141652
Ford Bronco Alpines installed! 20240408_141152
Ford Bronco Alpines installed! 20240408_141618
Ford Bronco Alpines installed! 20240408_142336
Ford Bronco Alpines installed! 20240408_143426
Ford Bronco Alpines installed! 20240408_143638
Ford Bronco Alpines installed! 20240408_142207
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
Although not an audio expert, I did find that the original programmable amplifier settings on my non-B&O factory sub in my 23 Big Bend were inadequate. When I did the same swap as you with infinity speakers, I also reprogrammed with Forscan for 2 ways in the new speakers as well as ensuring the subwoofer was enabled. What a difference. I actually had to turn the base way down in the audio settings and am quite pleased with the results. @RagnarKon has some excellent posts on the Forscan setup stuff for audio. Couldn't be happier.
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
Trust me, the upgraded system is no upgrade...
RagnarKon
Ford Bronco, Escape, Focus
Adding an amp is the biggest bang-for-your-buck.
If you do replace your subwoofer at some point... then you'll also need a new amp for that subwoofer... which turns it into a rather pricey upgrade. So I personally think it's better to upgrade the amp on the other 6 speakers before looking at the subwoofer.
Ninjak
Miami
I run the Alpines S2's in the back and a set of components in the kick and front locations. I have the B&O made a difference in sound, but I still need to do the sub, and probably add the Kicker people add who have the B&O to get the good sound from the sub.
Peepers
Peepers
Stacey
TN
2024 Bronco
Thanks for the info. I haven't messed with Forscan yet. I have the cable and adapter but am a little overwhelmed when it comes messing with it.
Johnny Mo
Westchester County, NY
teachu2shoot.com
100% What a disappointment for an "upgraded" sound system. Glad this forum exists, I was able to do a great upgrade for a "reasonable" amount of $$.
