Aftermarket Hitch
Bigmoose
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Is that the FullSwing? How do you like it? Some of the reviews mentioned that it's a beast to install and has some rattle to it.
It does swing out to allow a hatch or tailgate to open. Not sure of the model name. This was their first version and is about 12 years old or so and still going strong. It is definitely not light but its not hard to install by any means. Also Zero rattle.
El Duderino
Upstate New York
4DR MIC 2.0 Big Bend (2.3) A51
Awesome, glad to hear it. Thanks!
Bigmoose
Bigmoose
Jon
RI
Just looked it up. Its the Yakima SwingDaddy 4 Bike rack. Only cost $200 back in 2013. Weighs about 50#.
El Duderino
Upstate New York
Thanks for the follow up; looks like that specific rack has been discontinued. Scanning the Yakima website it becomes very clear that it ain't 2013 anymore. $200 nowadays might get me a Yakima sticker.
Bigmoose
Bigmoose
Jon
RI
Yes. Definitely discontinued. $200 was still a deal back then when Amazon deal of the day was just a single good deal. MSRP back then was still $499 I think.
DubZuc
Zuc
Tampa
‘21 2 Door Base & ‘23 4 Door Basequatch
I have a stock base model 2 door and just acquired a jetski. I'm looking to purchase a trailer hitch but not sure which size tow ball mount to purchase. I'm new to this so i'm hoping someone can help me? From what i'm seeing, I need to choose ball diameter and drop size...
HBTFD
Newnan GA
F350
Your jet ski trailer should have the ball size stamped on the tongue. It’s going to be 2” or 1 7/8”. With your jet ski trailer level measure the distance from the tongue to the ground. Measure the distance from your bronco’s hitch to the ground. Subtract the trailer measurement from the bronco measurement and that’s how much drop the receiver you buy needs to have. If you can’t find an exact match you want the trailer to angle up (tongue higher) by an inch or two.
andyhahn
Andy
I appreciate this post, helped me with my decision and install. I went with the Curt hitch and had no issues installing it onto the frame.
Ford Bronco Aftermarket Hitch PXL_20230413_164559364.MP
Ford Bronco Aftermarket Hitch PXL_20230413_175712009
Go Devils
Reed
I found this to be a better option for my towing needs rather than an extension. Clears the spare tire just fine.
CURT 45260 Class 3 Trailer Hitch Ball Mount, Fits 2-Inch Receiver, 7,500 lbs, 1-Inch Hole, 2-In Drop, 3/4-Inch Rise https://a.co/d/57EjeuW
Go Devils
Reed
As a reminder, any extension will lower the maximum hitch weight. We towed a small U-Haul trailer with no problem at all. A jet ski should be fine.
  • Like
Reactions: Cat
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Thanks for this info and a link.
I am looking to tow a U-Haul with two Harley cruisers behind my WildTrak.
Bike will weigh ~1500 pounds. Not sure about the trailer weight yet.
Will this hitch, in your link, be ok?
Go Devils
Reed
Should be fine. Tongue weight on uhaul trailers is nominal. But don’t put too much weight on the hitch itself. 3500 is max tow weight so the 2 bikes and trailer should be fine. I would be comfortable with it and I’m a cautious person when it comes to towing.
jrm5723
john
Frederick MD
2023 bronco
Question. Is the oem ford hitch for the bronco the same as the hitch for the ranger?
