AFE charge pipe BOV....
JunitoNo1
Jorge
Detroit
Yo,
Anyone own the AFE charge pipes and attempted to put an aftermarket BOV on them?
I've attempted both the boomba and the turbosmart and neither of them sit flush. The boost sound is significantly weker when compared to the stock charge pipes with either BOV installed
Am I missing something?
Ford Bronco AFE charge pipe BOV.... 20230831_181422
Bigfx
Is there a gasket that came with the bov?
CarGuy
New Jersey
2023 Ford Bronco
Is the pipe on the left (in the picture) threaded? It looks like you’re bottoming out on that pipe and can’t pull the two parts together.
JunitoNo1
JunitoNo1
Jorge
Detroit
So, I've detected the issue. This port is too tall for the aftermarket BOV to sit on.
The reason the stock BOV sits is because the plunger is free and unrestricted, so it's already being compressed by about 2mm when fully seated. The turbosmart plunger is tucked within the solid housing, so nothing there to compress.
So I can either find some sort of spacer to fill the void, mill down that port myself, ooooorrrrrr return the damn thing 😑
Ford Bronco AFE charge pipe BOV.... 20230826_193446
Ford Bronco AFE charge pipe BOV.... 20230901_181257
JunitoNo1
JunitoNo1
Jorge
Detroit
Follow up:
In case someone else runs into the same issue. I'm hearing that there SHOULD have been an included gasket with the kit to fill this exact void. For me, there was no gasket with the hardware and it wasn't listed or mentioned anywhere in the instructions. Possibly a different revision?
I've reached out to the vendor and supplier to clarify on this, but no word back yet.
Sooooooo, I ended up making my own 😅
Found this at the hardware store, and it was a perfect fit after I drilled some holes for the fasteners to pass through. Now both setups, the turbosmart and the boomba, seat perfectly and sound as they should.
Ford Bronco AFE charge pipe BOV.... 20230902_113151
Ford Bronco AFE charge pipe BOV.... 20230902_104138
Ford Bronco AFE charge pipe BOV.... 20230902_111941
JunitoNo1
JunitoNo1
Jorge
Detroit
I thought you were referring to the o-ring 😑 no solid gasket was included with either kits. I wasn't invited to that party.
Bigfx
That’s probably what’s missing maybe? Let me look at the stock one
Bigfx
Yeah no gasket on mine maybe the screws got cross threaded?
Ford Bronco AFE charge pipe BOV.... IMG_9424
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
I was going to suggest using RTV silicone as the gasket, but looks like you got it figured out.
Smitty1979
Jason
Glens Falls
1968 F-100, 2016 F150, 2021 Bronco sport
Follow up:
Any noticeably mpg gains out of just the AFE charge pipes?
JRod2.3BL
MD
2.3 7-speed
I installed afe charge pipes, afe momentum gt intake, and mishimoto intercooler on my 24 2.3 badlands a couple weeks ago. i lost 2mpg, however it does seem like it has more power when excellating and passing especially at 2500-3500 rpm range
JRod2.3BL
MD
2.3 7-speed
has anyone else had a similar experience losing mpg with the install of charge pipes and a larger intercooler?
Incinr8
1973 Dodge Power Wagon
Stepping on the Gas a bit more?
JRod2.3BL
MD
2.3 7-speed
I don't notice stepping on the gas more, but I could be because it's noticeably more fun to drive now
