Additional Engine Bay Fan (forward aux switch use)
530Squatch
Nicholas
NorCal
2002 HD Silverado Duramax Turbo Diesel
Hey B6G-
(@Administrator - feel free to kill this thread if it exists elsewhere... gave it the 'ol college try and came up empty handed)
Been thinking about uses for the 6 Aux bay switches and something that piqued my interest was adding a "push" fan to the front of the radiator and/or a hood-mounted one (under the hood, obviously) to dissipate heat. I know there's a "pull" fan like most other vehicles and was wondering if anyone 1) had experience with adding a fan in this area to keep the engine bay cooler and 2) if you had any opinions on do's or do-not's. I'm in California and we get weeks of summer heat over 110 and my current vehicles struggle to keep the car cool as well as keeping the engine cool... especially my poor '02 2500 HD Duramax Chevy quad cab. That may be an exception, but I also hope to have my Bronco live that many years, hence my curiosity.
I plan to use my Bronco as a daily driver -hell, I want to live in the dang thing as much as I can- and there is a decent amount of stop-and-go traffic, as my commute is 25min each way on suburban roads. I'd like to stay as cool (as a 38yo dad can) as possible. Appreciate your advice!
  • Like
Reactions: abe
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
I used to add them to Baja trucks and pre runners that ran off a switch. I can imagine it helping with excess heat in SoCal, also. Trouble will be finding a place to mount it in that busy engine bay.
530Squatch
530Squatch
Nicholas
NorCal
@De Brus Thanks, glad I'm not totally out in left field. I get to sit in some Broncos on Thursday so I'll be sure to take some measurements forward of the radiator then see if the current marketplace offers something. I'm guessing The Flannels won't let me monkey around with the hood opening-and-shutting it to get a height/ depth gauge... maybe there are some CAD specs out there that'll show what the space looks like. But probably wishful thinking!
De Brus
De Brus
Washington state
Derale makes some good fans that are built to take a beating. Plus there are a ton of sizes/configurations to choose from. You may want to check them out.
530Squatch
530Squatch
Nicholas
NorCal
@De Brus Thanks so much!
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
Erock
US
2018 F150 Alpine edition
Yep, Derale makes some pretty good stuff... they also have oil and trans coolers that fit in pretty small places... that assist in keeping things cool (I’m referring to the powered ones, not radiant type). I have a dual unit now, but would rather have 2 of the 5” ones for my old truck.
HBTFD
Newnan GA
F350
Put a raised cowl on your hood to let the heat out if you are worried about it.
530Squatch
530Squatch
Nicholas
NorCal
@HBTFD very true. Could be that I'm irrational about the heat. Let's hope it doesn't come this far!
HBTFD
Newnan GA
F350
Zero humidity and 110 F makes it tough on an AC system. Where I live they do well in 95F 90% relative humidity.
530Squatch
530Squatch
Nicholas
NorCal
@HBTFD yeah no doubt- I lived several years in central Florida... by the time you walk from the house to the truck you are soaked!
Rivers90
Ben
Southern California
2 Door Base Sasquatch
With all the testing in Johnson Valley I would guess cooling is not a problem for the bronco.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Ford Bronco Additional Engine Bay Fan (forward aux switch use) D38F489E-505C-4E60-AEE0-0892F0441446
Ford Bronco Additional Engine Bay Fan (forward aux switch use) 1618842892814
Take your Bronco to the next level with the muscular look of a Hood Scoop.
  • Designed to complement the retro-style of the Bronco
  • Thermoformed with high impact multilayer ABS Senoplast™ polymer combined with a patented interior overmolded elastomer finish
  • OE quality scuff resistant Satin Black finish
  • Easy no drill installation using 3M double-sided tape and 3M 540 adhesive
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
Has anyone seen info about auto trans cooling on the Bronco? I've added aftermarket trans coolers to my 4x4s, ever since smoking a trans while off-roading. I'd highly recommend adding a trans cooler to the Bronco, unless it already has sufficient cooling capability.
The 10-speed has a cooler on the transmission itself, mainly a heat sink. They started with that on the F150’s when they started putting the 10-speeds in them. For instance, the models previous to the 10-speed had an “upgraded transmission cooler” for the Max tow package. After the 10-speeds, they just use the cooler on the transmission.
To the OP, I really think you underestimate the power of the factory fans. Unless you are running a ton of boost or pulling, it will stay cool.
There is also the problem of the active grille shutters, disabling them and the codes it may or may not throw.
