Adding USB to a non Lux dash ?
wyobronco
Clint
Wyoming
'21 Bronco Black Diamond 2 DR
I will be tearing the dash apart in the near future to add a GMRS radio, amp, and a couple other things.
I would like to add a USB port to the top of the dash, hopefully with standard and USB-C ports on it. I have no problem cutting the dash and mounting these.
Does anyone see a problem with splicing the USB wires that are currently in place to provide these connections?
Should I add a hub? I dont care about carplay and things like that on top of the dash, just need power to charge devices.
I thought about running to the fuse panel but dont I need something so Im not sending a full 12V to the USB cable?
Thanks for any suggestions!
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I would not use any part of the stock USB system. I added a port on top of my dash and ran the cord down to plug in the console. The power cuts in and out and doesn't appear to put out very many amps.
wyobronco
wyobronco
Clint
Wyoming
I see options for boats, and it looks like they just run directly to the battery. It seems like that would be the solution?
RHeinz
Ric
Houston, TX
Yup. Blue Sea Systems
RC Bronco
Kansas
Yours cuts in and out? I’m not having any issues following what you did… yet
Rick Astley
Up Doug's ass
d
I would follow some of the excellent articles already written on this.
For example, here's the full how to for accessing everything and how to put a proper USB port in the rig. Just bypass the massage bits and go up to the dash, but this article is a great starting point instead of a generic question.
https://www.bronco6g.com/how-to-magsafe-wireless-charger-install-in-factory-location-diy/
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
I'm looking to do this too!
Gonna go with these...
Usb flush mount
Probably add a set to the back. Have 3 girls and need more USBs in the 2nd row.
Tricky Dick
Dick
PNW
Yes I use one of those chargers that has a motorized clamp and often it wont charge, sometimes won't even operate the clamp. I have the same one in my pickup run off a cig lighter USB adapter and it's never given issues, so I'm assuming the problem is the stock USB port not having enough amperage.
Copperhorse73
Justin
Mooresville, NC
I’ve done this mod several times, I tap into glovebox aux wire, run to aux6, which i leave always on to power USB, gmrs and amp trigger wires
Ford Bronco Adding USB to a non Lux dash ? 4E84FFF0-9BB4-4441-A1D3-254BC44D456A
HeHateMe
San Antonio, TX
Yep! Those are the ones I linked. I think from one of your pictures in another post. Much appreciated! 👏
I've done it too, but not on this vehicle yet and not these mounts in particular (I've done the cigarette lighter replacement, with voltage reading).
wyobronco
wyobronco
Clint
Wyoming
On the left and right hand side of that pocket on the flat panels, is there enough room to do that same thing? I would like to keep that pocket open if possible.
Copperhorse73
Justin
Mooresville, NC
Not sure about that, I’d probably do some dash disassembly , and get a peek before drilling there
HeHateMe
San Antonio, TX
Rivers90
Ben
Southern California
2 Door Base Sasquatch
Were you able to install the USB ports and was there room to have them to the side and not in the center?
