Adding Hero Switches for Aftermarket Lockers
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
Was curious if it is possible to add the hero switches for any aftermarket lockers or if I have to go the manual switch route
Ducati1098
The factory hero “switches” in the bronco aren’t actual switches, It’s a module. So I don’t see a plausible way of making them work for something else.
I think folks have got the rear to work, but I don’t know about the front. As Ducatti says - it isnt just a simple switch if you want it to integrate with GOAT and such and use the OEM buttons.
But you absolutely can just use a simple switch to add lockers - just not with Hero buttons
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
Thanks for your guy's help
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
Is it possible to make it work with Forscan and wiring it somehow?
NC_Oak
2024 4 door 2.3 sasq
hero switches are too close together. I only use the front and rear lockers out of those switches anyways. But I think the front and rear positions should be switched anyways (I might switch the wiring one day).
The world is your oyster if installing aftermarket switches - dealers choice
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
You could use an AUX switch if you have them
