Adding a amp or powered subwoofer
Bryanm
Raytown Mo.
2021 Ford Bronco big bend/2022 Badlands
Looking for pointers. I've already replaced my 6 factory speakers on my 4 door big bend and would like to add a amp and sub, or powered sub. Would like information on what line output converter or other options people have used and if possible pictures of where to tie into the harness.
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
I used kicker key amps for mine.
Hossfire
Richmond, VA
'06 Jeep Commander
cmcbronco
Illinois
2012 f-150 FX4
Went with the kicker 47key500.1. Has LOC built in. Working on install now and I’m hoping to have it done next week sometime.
bluford
Kia soul
I just tied into the lead speaker wires from the radio at the kick panel speakers, then ran the wires back to my amp and connected to high level inputs. You can use a high-low level convertor to attach RCA cables to the low level inputs on amp if needed or preferred.
Kick panel speakers lead wires.....Driver side: Blue is positive, Grey/Brown is negative. Passenger: Yellow/orange is positive, Green/Brown is negative
Bryanm
Bryanm
Raytown Mo.
Thank you!
da_jokker
Jeep Wrangler JKUR
There are folks that are really close to unlocking the signal to the rear pods. Forscan has a couple settings, and then the real fix sounds to be the JBL flash even if you don't have the actual sound bar.
Doing this would allow you to tap off the rear signal instead of having to run wires to the front (thus keeping your front to rear fade working).
cyclonend
Atlanta
Taco
I have seen a few post that the JBL soundbar is not working in the MY22s. I am guessing it is the flash that is broke.
da_jokker
Jeep Wrangler JKUR
Yeah, that's a bummer as well that I'm waiting to hear more about. One thing that was recently discovered was that the JBL flash can appear to do nothing if you leave in the stock rear speakers because of their filters.
All I can say is WTFF (that last F is for Ford... You can figure out the first part :) )
Bryanm
Bryanm
Raytown Mo.
Did you tap into the speakers at each kick panel speaker or from the loom at the bottom of the head unit behind the climate controls?
bluford
Kia soul
I tapped in at each of the kick panel speakers
2021Bronco 4dr
I had great success with kicker hideaway. Very pleased. Tapped kick panel speakers
‘21OBX
90Bronco19
2022 bronco outer banks
I popped one of these in. Got the harness kit #1 from plug n play kits.com
I was leery on it because of the low price but it sounds great and takes up very little room.
Ford Bronco Adding a amp or powered subwoofer 542F8576-E745-4CB2-9FEB-65251D813263
