ACC without LUX using FORScan?
JBlanco
Julio
Charlotte NC
wcmaness
Wesly
Arlington, TX
'21 Bronco OBX; '11 Armada; '02 Tahoe Z71; '91 XJ6
I have an Outer Banks - High Package (no ACC). BUT - I do have the ACC sensor the other referenced thread says is the sensor. With this in place, can it be activated or "turned on"?
Ford Bronco ACC without LUX using FORScan? ACC
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
Following. I have the high package and would love to have the ACC.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
I believe I read that is just the box where the sensor would be if you had the LUX package. Apparently it opens and if you have ACC, the sensor is inside, if you dont have ACC, the box is hollow. I have the high package and this box but I havent look inside yet
JBlanco
Julio
Charlotte NC
can you feel electrical cables behind it?
‘21OBX
90Bronco19
2022 bronco outer banks
Nothing behind it except ugly active shutter parts. I also have a OBX high package. I was hoping to remove the box for better flow to the intercooler. I still may end up remove the lower active shutters(after warranty is up) I want as much air hitting the intercooler as possible.
JBlanco
Julio
Charlotte NC
Yes that makes sense. I don't believe the aerodynamics benefits of the active shutters are significant in a vehicle shaped like a brick.
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
In the F150 if your vehicle does not have adaptive cruise control then you will not have the sensor. So how can you hack into a sensor that you don't have?
These types of questions are premature as the bronco is not out yet. So if you want an honest answer then it will have to wait until the bronco comes out and someone tries it and I bet very few will try it.
If you want ACC and can't afford the LUX package, a better course of action is to get a part-time job as you have a solid 10 months before delivery.
Re read the post. He said he hs most of the sensors and what he is missing can be bought. Thus the question resides in can adaptive cruise control be activated in forscan
Brnzbronc
Indianapolis
Hey so removing the active shudders will throw a DTC code and cause a reduced power scenario, I’m working on a way to get more air the Intercooler myself. It limits the boost to only 14 psi.
mpeugeot
Probably not if you only remove the actual shudders, but leave all the components behind (eg anything electrical), but probably will require some trickery.
