Ac vents falling out
Aaron james
Aaron
New york
2022 ford bronco badlands 4 door
Hi anyone ever have this problem I can’t put it back without pieces flying off
Ford Bronco Ac vents falling out imag
  • Wow
Reactions: LCW
Carnutdallas
Dallas Burbs
Tesla Plaid, Duramax Suburban, Ferrari F355
Must take whole unit out and put in from backside - sort of. The body comes apart and the vents go in. This is based on dealing with this in multiple brands of cars. Patience is the key, but again, must get the main body out. -R
jrollo7
James
NY
Range Rover Sport
Here you go. I changed the color of mine so this video should help you.
Lifeliberty
Moonbeam👀
Columbus, OH
If make sure you aren't missing the top/bottom gaskets
KABQ
Aaron
Albuquerque, NM
Why didn't you just pull off the tab to change the color?
jrollo7
James
NY
Range Rover Sport
Because you have to take put the whole piece . The colored tab doesn’t pull out from the front.
jrollo7
James
NY
Range Rover Sport
Did you watch the video? It explains the whole process.
KABQ
Aaron
Albuquerque, NM
I will admit to not watching the video, but I replaced my Base (gray) tabs with orange ones. I was able to get a curved pick underneath the tabs to get them to release from the vent without removing anything else. The new ones clipped solidly into place with no slop.
jrollo7
James
NY
Range Rover Sport
Interesting. Take a look at the video-it’s short. Maybe the vent design changed since the video clearly advises that the colored tabs only disengage from the back.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning! If you're still experiencing this concern, please send over a DM with your VIN and Ford dealer info.
KABQ
Aaron
Albuquerque, NM
Here you can see the small tabs, two each top and bottom of the tab. All you have to do is carefully open up the tab and pull it towards you. Hope this makes someone's life easier!
Ford Bronco Ac vents falling out PXL_20231212_141632835
Ford Bronco Ac vents falling out PXL_20231212_141625954
Lifeliberty
Moonbeam👀
Columbus, OH
The video way is so you don't do any damage to the tabs when you remove them. I've seen some pretty beaten tabs on here, it's like people used a hammer to remove them
That first tab is always experimental lol
Headsong
Now @Ford has come to the rescue!!! LOL....
jrollo7
James
NY
Range Rover Sport
That’s definitely a lot easier and makes sense.
