AC not keeping up.
Lèòn
Jersey
  • Thread starter
  • Banned
  • #1
How's everyone today?
Real quick, when I'm accelerating, AC comes out warm, but when I'm just cruising or stop, it's fine and icy. 34k miles, '21 Badlands manual, mods in sig, and haven't taken her offroad in months, what could be going on?
Thanks in Advance
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
is the GOAT selector in ECO mode?
Bonz50
Tony
Hamilton, AL
05 F150 S-Crew
IIRC most compressors are clutched that under hard acceleration they disable so the motor isnt dragging extra resistance. that may have changed but several years ago that was definitely a thing
robo
Rob
Santa Clara, California
2012 Subaru STi hatch, CG 2022 Badlands Sas
Not sure, but it might be normal to cut AC for wide open throttle. I've had other vehicles that seemed to do that. I just assumed it was to allow full power to accelerate.
HotdogThud
mk6 gti, '21 MoarDoor
if I had to guess, a cooling fan clutch is going out. works fine when passing air over the condenser, but when there's not enough volume of air, it shuts off. (had a BMW and a VW does the exact same thing, same symptom and solution each time)
Lèòn
Lèòn
Jersey
  • Thread starter
  • Banned
  • #6
I never use eco mode, so it's not that
Hmm, maybe. Also seems I need to drive it to get it to blow cold in the first place, then it works fine
What kinda job is that? I still got a bit of warranty left, think it'll be covered?
Lèòn
Lèòn
Jersey
  • Thread starter
  • Banned
  • #8
If you're still under the 36k warranty, I see zero reason it wouldn't be covered. I'd raise holy hell if they tried to push back on that.
I'll call and make an appointment soon then. Thanks Thud
60sIron
Thunderbird
Wide open throttle A/C compressor clutch cut out, when you push the go pedal hard enough the computer diverts all power away from the A/C and to the wheels.
Perfectly normal
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
The A /C compressor is turned off by the PCM at wide open throttle or under heavy throttle/heavy load to give maximum power to the wheels. That has been the case for a long while on about all vehicles on the road.
DD214
Western Mass
2018 JLU Sahara, 2015 Pilot, 2022 Bronco
Just before you punch the gas, in your best Capt James T Kirk voice scream, “Scotty, divert all power to the main thrusters“ and mash that gas pedal to the floor. It won’t fix it but it will be funny as hell.
ShaunB
Shaun
Houston
2004 F150
You could just simply have a leak and now the system is undercharged. The compressor will cycle off more frequently under loads, due to a lower system pressure. I’ve replaced a few leaky evaporators and condensers on 21-23 Broncos.
Lèòn
Lèòn
Jersey
Now I will do that, apperciate that!
Bringing her in the 12th, so I'll find out what it is soon enough (Gotta love this time of year, they get booked fast)
Haven't noticed that in other vehicles before, so gonna go with Sam B above with it's probably a leak. Still, I'll take it into account, Area 51
