genesisoffroad
Shane
Olive Branch, MS
www.genesisoffroad.com
'21 Bronco
These days everyone wants to use more and more electrical accessories in their vehicles. If you need to plug in a fridge, camping gear, heating blankets, charge your cell phones, tablets, camera and drone batteries, and more, you'll quickly realize you need more power outlets to plug everything in.
Genesis Offroad designed this easy to install Power Box to give you 3 extra outlets in the back of your Bronco. On our website you can choose a 12v power socket, a dual USB charger, or a voltmeter for each of the 3 positions, and we will assemble it to your specs so you get exactly what you need.
Simply secure it in place under 2 factory hard top bolts in the rear cargo area, and route the included 20' long wire harness behind the interior trim, through the firewall and over to the battery.
If you have our dual battery kit installed, then you'll connect the wire harness to the power & ground bus bars - that way everything plugged into the Power Box will run from your second battery and will not drain down your cranking battery. We will be shooting a detailed installation video soon.
If you do not have our dual battery kit installed, you can still connect the wire harness to your stock battery to have constant-on power available. Just be careful and don't drain down your cranking battery!
As of 7/26/24, this product is in production and we expect it to begin shipping by late August. Go ahead and get your order in now to be the first to receive it! Click here to learn more and order - https://www.genesisoffroad.com/bronco-power-box
Note we designed the Power Box in a 2 door Bronco. We don't have access to a 4 door, but we're pretty sure it will fit, just need some help testing it in a 4 door, so here's a special offer - place an order for the Power Box and if it does NOT fit your 4 door, just send us some detailed pictures so we can see what needs to be adjusted. Then we will send you a return shipping label. Once we get it back we will give you a full refund including your shipping charges. If it DOES fit your 4 door, great! Send us some good pictures of it installed for our website, and we will give you a 50% REBATE back to your credit card! This offer is only good until we get confirmation from someone, then we will update this post.
Ford Bronco New Power Box from Genesis Offroad! Easily add extra power outlets in your Bronco power%20boxes_finalized-6
Ford Bronco New Power Box from Genesis Offroad! Easily add extra power outlets in your Bronco Power%20Boxes_Finalized-7
Ford Bronco New Power Box from Genesis Offroad! Easily add extra power outlets in your Bronco Power%20Boxes_Finalized-32
Ford Bronco New Power Box from Genesis Offroad! Easily add extra power outlets in your Bronco Power%20Boxes_Finalized-31
Ford Bronco New Power Box from Genesis Offroad! Easily add extra power outlets in your Bronco Power%20Boxes_Finalized-29
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Nice but pricy...
genesisoffroad
genesisoffroad
Shane
Olive Branch, MS
'21 Bronco
Nice but pricy...
I hear ya brother. Please trust me when I say I'd love nothing more than to be able to lower our prices back to 2019 levels. If our input costs ever come back down, I will do that, but as of today I do not see any signs pointing to prices going down in the foreseeable future.
BoverW
J
Socal
If the 50% off includes the dual battery kits :), I am in :sneaky: .
TheShark
Could be a solution to the crappy 12v factory outlet in the cargo area. I've already fried one of the outlets with my Dometic fridge.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
I would love to see how you run the cable from the battery to the 12v location in the cargo of a Bronco. The installation video still shows a jeep. Or if anyone knows of a video showing a cable run like this, a link would be helpful.
AXMRDR
Central Arkansas
'22 Bronco, '02 F350 4WD Crew, couple of Harleys
Maybe I missed it, but I didn't see the wattage rating.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
SeptuagenerianSasquatch
Randy
Massachusetts
Charging drone batteries off of this would take forever. Especially if I was running a fridge too
I ran a fridge okay on a 5-day trip. My procedure is to cool it down the night before, running it off 120v house current. Then I load and plug it into the 12v in the back. I went with this splitter because I was also running a low-amp LCD dust light off the other 12v opening, and I could keep my camp light and backup radio charged off the USC ports.
That provided plenty of power to keep the fridge good and cold while driving.
Both the fridge and the Bronco have battery usage regulators to shut down power when low battery juice is sensed. But these fridges are thermally very efficient, and my perishables stayed cold and safe overnight. Then I started up the engine to idle for 10 or 15 minutes in the morning. The fridge restarted. Everything was re-chilled.
I didn't bring ice cream, so I don't know if this regimen would have kept that frozen. Worked for me, but YMMV, as they say.
TLO
Canada
youtube.com
2 door
Available with USB-C and if so, how many and what is the output wattage?
Thanks
