Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
Turned my outer banks grill into a hybrid heritage with these white inserts. I initially installed the black ones, but thought after my white wrapped top, spear decals and old school badge, I'd switch to white.
Inexpensive and easy to install and remove (if necessary, with pry tool).
Outer Banks Grill Inserts
Ford Bronco Outer Banks Heritage Style Grille Inserts 20240724_172152
2door
AA
2022 Bronco® The Sasquatch™ 2-door
Turbocharged engines generate a lot of heat. I don't understand why would anyone want to deliberately decrease the efficiency of the cooling system by partially blocking the airflow with these grille inserts.
bradcd
Brad
Indiana
Saab 9-3
And you have a safari bar installed, blocking airflow?
2door
AA
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
Not sure I get all the hype about reducing cooling??? Other grills have similar designs, and on my latest trip, didn't notice any issues with rising turbo temps.
As a side note, I'm installing Mishimoto Intercooler to offset. Hope that COOLS everyone's jets (or turbos).
Jazer
Jessica
2.7 OBX
Have had mine installed for probably a year now and there has been zero difference. JB4 can monitor all temps, incl IATs.
The black inserts clean up the OBX grill drastically.
Ford Bronco Outer Banks Heritage Style Grille Inserts 1721917792047-j2
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Have had mine installed for probably a year now and there has been zero difference. I have a JB4 and monitor all temps, incl IATs, and they are just fine.
Bronco looks great Jessica! Thanks for sharing. :)
2door
AA
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
HotdogThud
mk6 gti, '21 MoarDoor
We get lots of dust here in arizona, so i wanted to ensure I was getting the best filtration I could
Ford Bronco Outer Banks Heritage Style Grille Inserts 1721925956292-v6
GToddC5
Todd
South Jersey
www.bronco6g.com
Great idea, I can see some oil-impregnated K&Napkins coming to market soon!
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Black inserts look better than the white ones.
Patrickgault
Patrick Gault
South Carolina, USA
Ford Bronco, 2022 Outer Banks.
Call me weak but I tend to stay with the original engineer's design unless something compliments it. If I were smarter than them I would have built it.
mjcutri
M
Lisbon, Portugal / Pittsburgh, PA
2023 Bronco HE
Typically, most design decisions are not necessarily the best engineering solution, they are a compromise between design, engineering, manufacturing, and accounting...
