- Chris
- Mar 18, 2022
- 23
- 447
- 951
- Hemet, CA
- Website
- lobooffroad.com
- All of them
- Wildtrak
A while back we introduced our Rear Shock Skids designed specifically for the HOSS 3.0-equipped Bronco Wildtrak (see This Thread), and now we're following it up with a version that is optimized for the HOSS 1.0/2.0 Broncos. (NOTE: currently does not fit non-Sasquatch Badlands with factory Bilstein shocks. We're working on a revision that does, so hang tight a bit if you have that build)
Protect your Bronco’s shocks from trail damage with these beefy Rear Shock Skids from Lobo Off-Road. These skids are designed to protect the lower mount area of the HOSS 1.0 Hitachi (black) or HOSS 2.0 Bilstein (yellow) rear shocks that come factory-equipped on all 2021 and newer Ford Broncos except HOSS 3.0-equipped 2022-up Wildtrak (see our HOSS 3.0 Shock Skid). These skids are also compatible with most aftermarket coilover shocks and replacement struts. Does not fit Bronco Raptor.
The skid has a faceted front face that protects the lower shock body but provides angled surfaces to lessen drag on the rocks. The components are CNC laser cut from 3/16″ plate steel, brake-formed and fixture-welded for a perfect fit. They come with a durable fine-textured satin black powder coat finish, but if you’re using them the way they are intended you’ll probably be touching them up with a rattle can from time to time.
Here's a comparison of both versions side by side:
UPDATE! ALUMINUM VERSION NOW AVAILABLE!
There is now a version of this Shock Skid available in 3/16" aluminum. It is left bare (no powder coating) revealing the item's beautiful TIG welds. While materials and working with aluminum are slightly more expensive, not needing to powder coat them offsets costs so that the price is the same as the steel ones.
PROs of the aluminum version are
- Designed for HOSS 1.0 or HOSS 2.0 rear shocks
- CNC Laser Cut 3/16″ Steel Plate Construction
- Faceted Front Face To Help Maneuver Past Rocks
- Multiple Drainage Holes
- Grade 10.9 Hardware
- Durable Fine Textured Black Powder Coat Finish
- Proudly Made in the U.S.A.
- They are about 1/3 the weight of steel, for those who are taking every opportunity they can to save weight
- They will not rust and therefore will not need to be touched up with paint whenever they get scraped up
- They look badass!
