DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Gen2 Raptor Midtravel / TowRunner F250
Using Baja Designs S1s, our goal was to create the ultimate fog light kit for modular bumper. Our flush fit design replaces the bezel on the S1s and our bracket becomes the new bezel to create a true flush fit design. Looks aren’t everything though, we wanted our kit provide the best lumen/dollar value. With four pairs of S1s you get over 18,000 forward facing, useable lumens. Ensuring you can see every obstacle in your path with enough time to stay in control of your Bronco.
If you’ve ever been out on the trail or backroads and noticed that the stock headlights aren’t sufficient, you aren’t alone. Our flush fit fogs are a true fog light kit and are designed to provide incredible peripheral illumination to ensure optimal visibility and safety. On top of that, getting the lights aimed just where you need them is a worry of the past. No more knocking lights out of alignment when off-roading or washing. We optimized the position of these lights to give you the most visibility in lighting zones 1/2 which will compliment forward facing A pillars, or bumper/grill mounted lights.
If you want a clean fog light kit that looks factory and is actually designed to perform at the highest level, send us a message to learn more about our forum pricing and which beam pattern and color will be best for your application!
Ford Bronco Product Announcement: Hammer Built Flush Fit Fog Light Kit IMG_1548
Ford Bronco Product Announcement: Hammer Built Flush Fit Fog Light Kit IMG_1783
Ford Bronco Product Announcement: Hammer Built Flush Fit Fog Light Kit 20230923_172240_E3AA04
Ford Bronco Product Announcement: Hammer Built Flush Fit Fog Light Kit IMG_2244
Ford Bronco Product Announcement: Hammer Built Flush Fit Fog Light Kit 20230903_001027_5CE319
Ford Bronco Product Announcement: Hammer Built Flush Fit Fog Light Kit IMG_4028
Ford Bronco Product Announcement: Hammer Built Flush Fit Fog Light Kit IMG_5254
Ford Bronco Product Announcement: Hammer Built Flush Fit Fog Light Kit IMG_5253
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Cool setup and a great light selection. Since you are replacing the bezel did you retest for IP69K?
Bsenecal
Vermont
'19 Ranger crew cab, '17 Fusion sport, '68 Mustang
Am I missing a link to check prices?
DoYouBronco
DoYouBronco
Tyson
El Paso
hpbuilt.shop
The lights retain their water resistance even with changing the bezel because the gasket is under the lens, not the bezel. Because the bracket is an exact fit with the same torque specs, it achieves the same effect as the bezel. There was no need to retest, as it is effectively the same as replacing the bezel with another Baja designs bezel
DoYouBronco
DoYouBronco
Tyson
El Paso
hpbuilt.shop
Never mind I found another thread with that info, not interested in spending $1000 for dog lights.
I understand, Baja designs makes arguably the best off-road lights out there. With quality comes cost and we priced this kit very competitively.
Bigmoose
Jon
RI
G
Great info. Thanks!
Bsenecal
Vermont
usually it's for fog, but I guess it would light up dogs, too.
Yes is they do help to see either a dog or through fog.
Fat finger catches me again ☹
Finbox
FL
KLR650
They look good, but I just can’t get over the expose 32 screwheads
HPR23Wildling
Raleigh, NC
2021 Tesla Y, 2012 BMW 335is vert
Is there an amber backlight option for the white or amber fogs?
HPR23Wildling
Raleigh, NC
Also, saw some pics on the site where the screw heads were black?
DoYouBronco
DoYouBronco
Tyson
El Paso
hpbuilt.shop
There is no backlit option on the S1s. The screw heads come in a stainless finish. The reason for that is the black oxide hardware is prone to getting messed up during install, then rusting. Same reason we switched to stainless hardware on our tailgate reinforcement.
Chrome_Pony
Chrome
The Great Land
Finally! Been waiting on companies to realize the bezel replacement can make for some crazy designs: like doubling [or quadrupling in this case] the lights, rotating an S2 vertically next to a Squadron putting two S1s next to a Squadron.. the possibilities are significant.
