7MT hydraulic accumulator failure
tdhyden79
tdhyden79
Travis
'22 Bronco Bad-Squatch 2.3l 7MT
Well blow me down, I missed the earlier threads as well.
Thanks for posting your experience/solution @tdhyden79 !
Could a "clutch pulsation damper" be a part of why the Bronco's clutch feels so spongy, "slow" to engage, vague, and how the engagement point seems to change between each shift??
I would be most interested @tdhyden79 in any change to clutch feel after you remove this thing with your solutioin linked above. If it moves the clutch feel in a "regular" direction I'm going to remove it fur sur.
Do it immediately, if not sooner! The mush is gone.
MoePort
Maurice
Billings, MT
tdhyden79
tdhyden79
Travis
Yup, ordering
Thanks! I'm ordering the parts as well.
I assume bleeding is necessary after install?
Jeg's links:
https://www.jegs.com/i/jegs-555-110321-black-4-an-swivel-coupler
https://www.jegs.com/i/tick-perform...to-o-ring-female-quick-connect-clutch-fitting
Yes, you have to bleed it. I have a Motive Products Power Bleeder that I use for flushing brake lines on all of my vehicles. I purchased the cap for the Bronco
https://www.motiveproducts.com/products/1109-black-label-european-adapter-45mm?variant=10122660165
If you need the whole kit use this part number
https://www.motiveproducts.com/products/0109-black-label-european-power-bleeder?variant=6649612805
it makes bleeding the clutch a one person job.
I use Amsoil brake fluid, I'm a dealer so the price makes sense.
https://www.amsoil.com/p/amsoil-dominator-dot-4-100-synthetic-racing-brake-fluid-bfr/
If you want to buy "off the shelf" fluid, use Prestone Max DOT4, it has a higher boiling point than other brands which makes it better for Brake/Cluth applications.
https://www.prestone.com/product/prestone-max-dot-4-brake-fluid/
