- Bryan
- Aug 5, 2021
- 41
- 5,483
- 14,562
- New England
- Ford Bronco, Escape, Focus
- Badlands
It finally stopped raining... so amp install time!
And as usual... TL;DW—
Accessing the ACM (Audio Control Module)
The installation of the the amplifier depends on your particular amplifier and where you've chosen to install it. I'm very curious to hear where folks installed their amplifiers (both the Kicker Key 200.4 and other amps)—I think there may have been a better spot I didn't think of. Note there is lots of room under the center console for wiring/amplifiers/etc. The center console upper trim panel is held on with multiple clips (8-12 total).
Shout out to the fellow nutmegger(s) over at @plugnplaykits for making it super easy to install amps in the Bronco. Definitely would be cheaper to go old-school and splice the wires, but using their kits makes everything super easy.
Other videos/guides I've created on the topic of audio upgrades:
- Remove the center console grab handle—or trim plate if you have a Base Bronco. This is held on with (2) TP-30 "Bronco bolts"
- Remove the lower instrument cluster trim panel. There are a total of (2) clips securing the trim panel
- Unfasten the lower steering column trim panel covering the fuse panel. There are (8) plastic clips total.
- Loosen the 7mm screw on the driver's side securing HVAC & audio control panel to the Bronco
- Loosen the 7mm screw on the passenger's side securing the HVAC & audio control panel. The glove box will need to be opened to access the screw.
- Remove the HVAC module & audio control panel. There are a total of (6) clips secure the panel to the vehicle
- Remove the (3) wiring harnesses securing the HVAC module and audio control panel in place.
