Ducati1098
This looks like All vehicles built with the HOSS 3.0 steering rack. So for those of you who have added it to your Bronco, you might want to check with the dealer for a fix.
It’s only 163 delivered vehicles though. And unfortunately no way, as far as I know, to know if over the counter parts were affected.
timbal1963
Tim
Indiana
21 VB WT, 22&23 Bronco Raptor
Wife’s WildTrak is in the mix. Dang.
(Edit: Not on the VIN list later in the thread) 😅
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
It’s only 163 vehicles though. And unfortunately no way, as far as I know, to know if over the counter parts were affected.
It says the issue stems from assembly of the units. I’d assume over the counter units will be impacted too.
Ducati1098
Well it says damaged during assembly.
Is that assembly of the rack? Or assembly of the vehicle? That’s the only reason I wasn’t sure.
604Bronco
British Columbia
www.bronco6g.com
They probably damaged them during the assembly of the units, then for good measure, damaged them again when installing on the vehicle. Just to be safe.
Ducati1098
This is probably the most accurate thing I’ve ever read 😂
Beach_Bum
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
I don't know the details of when the damage occurred. They had their own Bronco fixed at the plant when it rolled off the line. Perks of working where the sausage is made.
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
Just like all recalls, I’ll worry when I see my VIN is directly affected. When I get a letter or see it in the app, until then Bronco on.
BigHoof
PA
Ram 2500
As embarrassing as it is, good to see them being proactive on issues.
brentutk
Brent
Nashville, TN
Eruption Green Wildtrak
Not all HOSS 3.0’s. Mine was built in May.
