goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
Here are a few pics of how 4600 team Kraker Fab Motorsports has dealt with making a stronger steering system.
Josh Atteberry and his Kraker Fab Motorsports team replaced the rack with a double ended hydraulic ram that is mechanically connected to a steering gear box. Pretty unique idea. The 3 factory Broncos used a Trophy Truck rack, so this is trying something new.
Ford Bronco Big Steering Upgrade on New 4600 KOH Bronco 325181034_724258439061242_7266565116519301508_n
Ford Bronco Big Steering Upgrade on New 4600 KOH Bronco 324934416_854727652248916_1229937009446041938_n
Ford Bronco Big Steering Upgrade on New 4600 KOH Bronco 325178045_547134384106171_2286143022803208721_n
They are also using the 74Weld portal hubs that the factory Broncos used.
Ford Bronco Big Steering Upgrade on New 4600 KOH Bronco 324935312_849538826273441_3046802706096222226_n
goatman2
goatman2
Richard
Bakersfield
gandgautorepair.com
Here's a couple pics of 2 of the builds stripped down. Looks like they are planning to run without the hardtops. No Ford sponsorship to be concerned with, and so how they look.
Ford Bronco Big Steering Upgrade on New 4600 KOH Bronco 324938861_6425043357509200_7588011598715253810_n
Ford Bronco Big Steering Upgrade on New 4600 KOH Bronco 321247847_538312801656249_3112714068903535841_n
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
That is some awesome thinking there.
Laminar
Iowa
Cougar
Are they just using the hydraulic ram as a linear bearing, and all steering power comes from the steering box? Super interesting!
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Here are a few pics of how 4600 team Kraker Fab Motorsports has dealt with making a stronger steering system. After King of the Hammers last year Ford sold 3 KOH teams a preproduction Bronco, that would normally be crushed, for a dollar. If all three teams get their Broncos finished and make it to the race, then there would be six Broncos racing this year in 4600 stock class. Assuming the three Factory Broncos also run this year.
Can I buy one for a dollar!
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
That's full hydro steer with a steering box for passing tech. I bet the pitman arm with be bent within the first mile of the race(looks like its designed that way). Makes me want to go to KOH.
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
I'm guessing that is a mock up or a partially complete steering arm. Final arm will most likely be boxed in and double sheer on that joint.
vrtical
Doug AI
GSMNP, TN
Fords
They should mod the doors just sayin 🙃
Bukin67
Randy
Southeast of Disorder
'67 Bronco Baja racer "The Bukin'eer"
That will be a great show if all 6 make it. Looking forward to seeing it in person!
TeocaliMG
Plymouth Michigan
Smaller than a superduty gear, I wonder what they are using. If I were going to the trouble of adding the RCB gear I would consider a beefy parallel linkage and skip on the rack. Both superduty and GM HD have parallel links that are very stout and might be able to be retrofitted.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
That's my guess, too. Looks like a hydro assist setup with a mocked up pitman arm. People do crazy things to get around rules but intending to have a bent up steering arm right below the oil pan seems too risky so I'm doubting that is the plan but we'll see!
