Which GOAT mode do you use most often?
  • Total voters
    849
amazingjason
CA
1987 Samurai, 1966 442
Which goat mode do you use most often?
RHeinz
Ric
Houston, TX
Wow! That surprised me! I drive in ECO because the throttle is less sensitive and I can get smoother shifts through the lower gears with the 10 auto. Yup, I’m a Grandpa!!
Anyone can stomp the throttle to the floor. Driving smoothly takes some learning (as the car learns me?) and finesse.
Edit: I guess only 2 people had responded when I had commented. I thought the SPORT MODE people would take it…..
Dude1967
Billy
2025 Ford F150 Tremor
Normal, 376 miles so far.
M4Madness
Indiana
F-150 FX4
I use Sport, and not because I'm an aggressive driver -- I have a little over 900 miles on my 2.7L and have yet to exceed 2500 RPM. I use it to lock out the top two gears, since I'm running 3.73's with 33" tires. And I'm getting 20 MPG as a bonus.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Normal. I have a stick shift. GOAT modes are silly marketing if you have a manual.
For the most part I'd agree with that. Sport seems to do nothing, but I've seen other manual owners rave about it.
M4Madness
Indiana
F-150 FX4
Don't forget that they affect steering response in addition to throttle response, as well as traction control.
AZ_Liberty
2007 Expedition
It makes the skinny peddle "touchier" which if anything gives you worse control. In theory it makes the steering stiffer, but I can't feel a difference.
I use Sport mode all the time in my wife's F-150 because I get better gas mileage. But the F-150 has one of those auto-magic transmissions with way too many gears.
carrellslake
Oregon
2022 Ford Bronco
I used Eco all the time when I first got the Bronco, but having to tell it to go back to Eco EVERY SINGLE TIME the engine starts, I gave up on it. That and the fact that it makes almost no difference with city driving.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Live a few miles from the beach so everyday it is driven, I use Sand mode. I also use Normal mode on the pavement.
For example, I took an hour cruise down the beach today before the impending cold front. Spent about 20 minutes (back/forth) in Normal mode driving there.
dgorsett
colorado
F250, Mustang, Explorer
Normal I suppose is the obvious winner since most time is spent on road. Eco and slippery feel dead, Sport and Sand are a bit lively. Plus how can I learn my vehicles response to my inputs if I purposefully tell it to modify its response to my input. That said I will use slippery on ice and I want to try Sand in deep snow.⁰
Marsalad
New York
2021 Bronco Big Bend
During a recent snowstorm I believe I uncovered a “secret” G.O.A.T. mode because when I attempted to shift into mud/ruts mode to disable traction control the vehicle made a terrible noise and I lost 4WD. I called it “fainting goat” mode. After waiting two days (!) for a tow truck the dealer told me I needed a new front differential and axle shaft.
So today when I ventured out into yet another snowstorm I just kept it in normal mode and everything was fine. So much for modern technology.
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
Thanks to Elliott I got to use Slippery in my Basesquatch for a trip. Was a beast. I did have a little dusting inside my softy b it the way it was blowing really not surprised, only in the back.
amazingjason
CA
Have you tried every mode? Have you always left it in normal?
