Ducati1098
New safety recall launched today for:
2021 Bronco built February 19, 2021 through September 16, 2021
2022 Bronco built September 1, 2021 through September 3, 2021 (Possible typo, build dates don’t seem correct)
REASON FOR THIS SAFETY RECALL:
In some of the affected vehicles, the side impact sensors may not have been properly installed. A side impact sensor that is not installed properly may not detect certain side impact events. The incorrect side impact sensor readings could cause the affected air bags to unintentionally deploy or to not deploy when intended, increasing the risk of injury in a crash.
SERVICE ACTION:
Dealers are to inspect for a missing B-pillar crash sensor mounting stud, missing retainer nut and/or loose mounting stud. If nut is missing a nut must be installed. If the stud is missing or loose, the dealer will follow the repair procedure to weld a new stud in place and apply a corrosion resistant coating. The dealers will be instructed to contact the Special Service Support Center (SSSC) to obtain a stud until service parts are available through the depots. This service must be performed on all affected vehicles at no charge to the vehicle owner.
Not sure how they missed welding on a whole stud for a crash sensor, but this should be interesting.
FleshTuxedo
A
PA
'22 OBX 2dr.
How can you find out when your vehicle was built? I don’t remember the exact date.
j_marinelli
Spring Branch, TX.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
SERVICE ACTION:
Plot twist: it was the MAP Supplemental Restraint System quality control team that Ford sent over to the Webasto plant to "fix" the quality control debacle there last year.
Also, Ford made MY22 units for 3 days in September last year?
Ducati1098
Ducati1098
Good point. I don’t think any MY22’s were built until December. That’s just the dates the recall gives.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
All of you who installed grab handles using those side-impact air bag bolts may want to remove the handles before taking it in. I could just see Ford telling you to pound sand.
Ducati1098
Ducati1098
Those are curtain airbags, this recall is for the sensor on the B pillar
604Bronco
British Columbia
www.bronco6g.com
DUSTYcazOREGON
Craig
2022 Bronco Black Diamond & 2025 Yukon Denali. 2023 Mercedes Adventure Wagon.
SERVICE ACTION:
I have been so lucky.....NONE of the recalls have affected my Bronco. (hopefully it stays that way and no problems with the MIC).
Ducati1098
Ducati1098
I believe your window sticker has a blend date on it that should let you know. If this is correct, someone chime in and confirm.
True, while it’s not the exact build date, it’ll give you an estimated guess if you’re close to the recall window
