4wp Bronco Wrangler 2Dr review.
Philly
Dallas, TX
2022 JL Rubicon
I hadn't seen this, but I am honestly bothered to no end by people comparing the Wildtrak with the Rubicon. People should know by now the Badlands is the direct Rubicon competitor.
5280Bronco
Denver
Its insane how people are still making this error.
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
How is it an illegitimate comparison?
Philly
Dallas, TX
2022 JL Rubicon
Rubicon Wranglers come with 33's and a sway bar disconnect. The Badlands comes with 33's and a sway bar disconnect. The Wildtrak comes with 35's and no sway bar disconnect.
The comparison isn't illegitimate, but it isn't the best comparison between the two vehicles.
AKBronc49
Russ
Anchorage, Alaska
If you have lockers, why wouldn't you use them. Other than for dramatic effect...
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
what wrangler would you compare the Wildtrack to?
Philly
Dallas, TX
2022 JL Rubicon
There isn't really a good direct comparison right now for the Wildtrak. I would say probably the Mojave when that finally comes out, as it's only a Gladiator trim at the moment, but that is only supposed to come to the four door models, still doesn't have 35's from factory, and I believe is missing a front locker.
Unless Jeep Changes something in their lineup, there is currently no direct comparison between the Wildtrak and a Wrangler so you have to take any comparison with a grain of salt on both ends.
Aaonter
Rick
North Bend
2020 Wrangler JLR
Although I agree that it will add a little articulation it still is not a big jump. There are plenty of videos with it engages the disco and the tire is still hanging in the air. There are also plenty of videos comparing these where the Badlands cannot keep the tires on the ground where the jeep does. The Wildtrack is advertised as their top of the line off roader. I think Ford did a pretty bad job with naming and advertising the Bronco and Bronco sport.
Ford Bronco 4wp Bronco Wrangler 2Dr review. 1635790118927
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
There is a big jump in articulation with a Badlands with 33's. The difference is less noticeable on a SAS version.
hellahella
Adrian
Nevada
Ford Bronco
BroncoPls!
Austin,TX
Ford Bronco 4wp Bronco Wrangler 2Dr review. 1635791997035
2-door Badlands, Non-SAS is a 700
Rough Rider
2018 Mustang Convertible
Did no one actually read the piece....of course not this is the internet.....
"Ford offers a few ways to get a trail-friendly option package, however, to equip a Bronco with the front swaybar disconnect system, you must select Badlands model. We had a Wildtrack and that trim level cannot be optioned with the system. Aside from that missing piece of tech, we got very close to an even match. Here’s how each vehicle was equipped. "
