4 door hardtop remover tool / device ?
bojibronco
des moines
2025 4dr Sasquatch
Do you not store the top on the lift ? It says you can that’s why I’m asking
you can leave it on the lift, even allows you to park under it with the top over your hood. I have a parking bump to stop me fr pulling too far up but I also put a bit of foam padding on it just to be safe.
I wonder if he took it off for the photo? No need to take it off. You can also stack the other panels on top of it.
2018 bigdog
Charles
illinois
2018 Tundra
I have the original Top Lift Pro and it works wonderful! You can store your top pieces on it and move it around the garage as needed. I did make a support piece that goes from the base up to the lifting platform when storing the top on it because it can be a little unstable (bouncy) if you don’t have one. I don’t think it’s necessary, but I just didn’t want to take a chance. This being the original version you can probably pick up secondhand pretty cheap.
I wish my garage was that clean lol
Johnny Mo
Westchester County, NY
teachu2shoot.com
Built a hoist in the garage - suspend it from the ceiling on a floating shelf made of uni-strut, threaded rod, aluminum 1x2 and padding.
Ford Bronco 4 door hardtop remover tool / device ? PXL_20240623_134755832
Ford Bronco 4 door hardtop remover tool / device ? PXL_20240517_233941631
Shawngod5269
Shawn
Marlton, NJ
2024 Raptor
You can store it on it, and i store it above my hood so it takes up almost zero space when it’s off. Way sturdier than the top lift pro from what I’ve read, even mentioned by someone else in this thread. If you buy it off their website you get 15% off with promo code
Ford Bronco 4 door hardtop remover tool / device ? IMG_2040
AzGrayHeritage
Keevan
Georgia
Azure Gray Heritage 24
What do you have between the roof and the panel?
Whiskey Bizness
Franklin, TN
2025 Bronco Badlands Sasquatch, 2025 F150 Tremor 402A.
I bought and installed a Lange Originals Hoist-a-Top. Their customer service was amazingly good when I ran into some issues getting the system balanced correctly for lifting the rear "clam shell" only.
Ford Bronco 4 door hardtop remover tool / device ? i-VxbzLm4-X2
Ford Bronco 4 door hardtop remover tool / device ? i-33xcRxd-X2
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
Wouldn't happen to have a pic of your "support" would ya? I have decided to build one myself just to take the stress off the top and put the weight back on the sides like it does when installed. Looking for ideas. Thanks
The support bar is in the pictures with the top on the top lift pro. It is a black square bar and I made it with extra bars that came with the top lift pro that are actually extension pieces so the top lift pro can be used with a Jeep Wrangler since the wrangler top is longer and needs the extra support that the Bronco doesnt need. in the picture with the green strap holding the center top section in place you can see the green strap that goes behind the support bar
retiredarmymp
Steven
Whitehouse, Texas
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
I use a Harkin Hoist, and wifey parks underneath. 🤠
Ford Bronco 4 door hardtop remover tool / device ? Screenshot 2025-08-22 1.22.40 PM
Ford Bronco 4 door hardtop remover tool / device ? Screenshot 2025-09-05 7.54.51 PM
