3rd brake light options (not the ring!)
CUZICAN
Lake Charles, LA
2022 Bronco Wildtrak Sasquatch
It may not be helpful, since I don't think they make them anymore. I mounted a rigid industries red rear facing series dually behind the spare. You might be able to achieve the same look with a red cover over a diffused white light. This also probably requires an 20" wheel, unless a smaller light is used.
Ford Bronco 3rd brake light options (not the ring!) 20240209_093827
Ford Bronco 3rd brake light options (not the ring!) 20240209_093840
Ford Bronco 3rd brake light options (not the ring!) Screenshot_20240209_105334_Gallery
Ford Bronco 3rd brake light options (not the ring!) 20240209_203703
mvilla
mvilla
San Francisco
4-door Badlands Bronco w/ Sasquatch package
Ford Bronco 3rd brake light options (not the ring!) IMG_3009
Ford Bronco 3rd brake light options (not the ring!) IMG_3008
Here’s an update:
So I swapped out my license plate frame for the @Metalcloak license plate mount and 3rd brake light. I also replaced the light that it came with a Cyclone V2 rock light from KC Hilites and a red cover.
I think it looks much better than the stock light that the MetalCloak came with.
I 3D printed a mount to hold the Cyclone to the license plate frame. If anyone is interested, I can share it.
I still have to add the license plate light to the bottom of the bracket, I am just waiting for a connector to come. I also plan on installing a digital rearview mirror and plan to mount the camera above the brake light so I will need to update my 3D printed mount to accommodate that.
https://metalcloak.com/bronco-6g-license-plate-mount-and-3rd-brake-light-kit.html
https://www.kchilites.com/cyclone-v2-cyclone-v2-led-single-light.html?attr_pim_lenscolor=5730
https://www.kchilites.com/cyclone-v..._pim_lenscolor=5767&utm_relatedproduct=native
mvilla
mvilla
San Francisco
That looks awesome, looks like your wheel is perfect for that setup. I like the way it frames the light in that smaller triangular section
CUZICAN
Lake Charles, LA
I don't know if I could have got any luckier with the placement. I did recently find a smoked cover for the light and I think I'm gonna call it done for now.
Ford Bronco 3rd brake light options (not the ring!) 20240214_140128
Ford Bronco 3rd brake light options (not the ring!) 20240214_140132
Ninjak
Miami
Not running a 3rd brake light for now, even though TOR allowed me to mount it up above my 37's. My Armadillo top has a 3rd brake light built in, so I will connect that when my top comes.
Docdownes
Christopher
Las vegas
Bronco Raptor
3rd Brake Light delete/relocate with Chase light mount
@Fast Intentions Inc. Raptor Chase Light Mount
https://www.fastintentions.com/product/bronco-raptor-uni-chase-light-mount/
@Baja Designs RTL Mini mounted to underside
https://www.bajadesigns.com/products/rtl-m-mini-led-rear-light-bar/
@Baja Designs S2 Sport mounted up top.
Switched lenses to amber and added S2 rock guards - made additional mod and attached the OEM Rock guard to the S2 Rock guard.
https://www.bajadesigns.com/products/s2-sport-black-led-auxiliary-light-pod/
https://www.bajadesigns.com/products/s2-single-rock-guard/
Gene Dios
Atlanta
Anyone recognize this light? Was on one of the rtr builds
Ford Bronco 3rd brake light options (not the ring!) 1000019598
