35s or 37s..that is the question...pic inside.
codydb19
Cody
Silverado
37s. Just by looking they are much taller than the 35s on the squatch
SilverII
DFW
The real question is whether it can take a 37" without any mods
codydb19
Cody
Silverado
@395N There was also a really good picture of both this Bronco and the 4 door Cactus Grey one that I saw. It showed a really good perspective on the different size between the two. However I can’t seem to find it ?‍♂
There’s just some question about whether the 4 door has 33s or 35s lol.
Monster1926
GMC Sierra 2500HD
Do you think that will be an accessory? Available from the factory when ordered? Dealer installed?
Most likely dealer installed. Probably something Similar to the mopar lifts. Retains your factory warranty on the components. I’d imagine it might hinder production if they installed it at the factory.
395N
395N
Orange County CA
22 Jeep Rubicon XR
I'm dead set on the 2 DR and if Ford offers a factory lift that will keep CV angles in check, I'll go 37's. There certainly appears to be enough room in the wheel wells.
FL Trucker
Ft. Lauderdale
F-150 Raptor, Fusion
OK_Hunter
Greg
Infinity g37
I definitely want to move up to at least 35x12.5 tires when the stock 315s wear out...I would think these should fit no problem on a stock bronco (obv Sasquatch).
BroncoFanBoy
Brandon
Az
Nissan
What is the estimated difference in mpg beteeen 33 and 35s, assuming you got correct gearing for each situation? Difference if you don’t regear for 35s? I read gearing makes all the difference.
I know I’m gonna get, if you care about MPG you shouldn’t get big tires. Not that I’m trying to set a record, just curious...
Merc4x4
steve
35x12.5 is not a 'move up'. It is the same size as the 315/70R17
315 Goodyear Duratrac is 34.4 x 12.7
35x12.5 BF Goodrich K02 is 34.5 x 12.5
Deleted member 2346
Guest
Ford uses the term “factory installed accessories” but I agree. The lift has to be a dealer option
Deleted member 2346
Guest
From this other angle the lower a arm (and thus the cv angle too) looked angled down kinda far for just a 2” lift. My worry is u don’t have much more downward droop left. I’d just do a full front lift that lowerS the diff and all.
Ford Bronco 35s or 37s..that is the question...pic inside. 5CFF8409-E8C6-4C31-985D-C70FF6EEDA75
