+30 or +0 Offset?
Oldhippie
Barry
Santa Cruz, Calif.
If you are only planning on 35” tires I would go with 30…”poke” looks silly and just makes it harder to get through the “tight” spots (of course harder on wheel bearings too). Guessing 0 may have “rub” issues with stock suspension too.
JL8jeff
Ewing, NJ
Looks good. What wheels are those?
They are the Pro Comp 1069's. They are similar to the old Mickey Thompsons.
Dmk08
GA
Walk
So can I run Method 8.5" +0 offset wheels on my 23 Badlands non-sasquatch and just add the fender flares? Anyone have a picture of how that will look. The tire calc says its going to poke out 2.5" more. Does that sound right?
Palooza
Palooza
Liam
Maryland
Bronco 4dr
Here’s a photo of a non-sas with non-sas fender flares with the +0 17x9 RTR Tech 6 Wheels.
Ford Bronco +30 or +0 Offset? IMG_8555
Ford Bronco +30 or +0 Offset? IMG_8557
Dmk08
GA
Walk
Looks good. So I guess since the wheels I'm looking at are 8.5" wide with 0 they will be about 1/4" less poke than that. Probably not far from flush with SAS fenders...
Palooza
Palooza
Liam
Maryland
Bronco 4dr
WhatsThisDo
J.C
22' Bronco
I’ve been wondering the same but with adding the Eibach stage 2 coil overs and some UCA’s if I should go zero or +30 on the offset.
Did you end up going with the zero or +30? I'm looking at getting the Eibach Stage 2 as well and can't decide which to go with. Don't want to get the Sasquatch fender flares, but not sure if the +30 with the lift is going to rub.
