2DR Auxiliary Fuel Tank
Silver-Bolt
Eureka, MT
Have you looked under the Bronco? There isn't much room for anything bigger.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
These folks are supposedly working on one. The downfall is it'll cost $2,000+ and that's not including install.
https://longrangeamerica.com
The question/problem is for the two door though? They have one for the later two door Jeep JKs so I guess we’ll see.
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
A second tank would have to go behind the rear axle where that big assed muffler is. Already some aftermarket exhausts remove that muffler, which would create some space.
BroncoAgain
La Verne, Calif
2022 Gladiator Rubicon, Ram 2500 6.7 4x4
As I recall the tank on my 1st gen was small but I had the aux tank that helped. For any 4x4 exploring gas was an issue so the jerry cans got used.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
One reason I went 4 door
Tricky Dick
Dick
PNW
www.TD-Distributing.com
At these prices adapting behavior sounds pretty good.
I've ridden bikes long distance many times and I'm used to planning routes for fuel every 100-150 miles. Having a family in a car results in about the same thing.
kpark_67
Aledo, TX
18 or 20? You have a 17 now. I ran mine dry on purpose to see how far past "empty" I could get and it took 17 gallons to fill. With the gas mileage, getting 1 to 3 extra gallons will only get you 18 to 54 miles extra. I think a better replacement tank and aux tank can do much better and maybe get close to 30 gallons total.
dingle87
Reese
West Suburbs of Chicago
2019 Ford Explorer XLT
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
I have read other threads and posts about it. The only way to do it is EXPENSIVE!! Because of sensors and vapor recovery, sending units etc. You would have to replace the original tank with a larger one, if Ford could have I suspect they would have. Add another complete tank for a dual tank set up with all the same systems in place. The one way I think most simple but probably dangerous? Gerry cans on either side of the spare with a hard plumbed transfer pump mounted underneath. You could ad 10 gallons. But what happens if you get hit??
@802Bronco Hit the nail on the head. Simple for diesels, logistical nightmare for gas.
I brought a F150 off the lot a few years ago for a great price but with smaller 26 gallon tank rather than 36. I had a good working relationship with my local service department - and they also do upfitting. We spent a lot of time researching options but nothing panned out in regards to dual / auxiliary / reserve tank. Fortunately in my case the OEM upgrade was possible so we did that. Out the door it was roughly $1,100 dollars, even with a refund for reusable parts.
Lèòn
Jersey
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
Every 2 door owner should Google “The Serenity Prayer”.
I just got back from a round trip from MT to AZ and back. 1200 miles each way. First long trip with the Bronco. Towing a camper. Averaged around 11 mpg (ouch). So…yeah…..I know all about that damn tiny tank under my 2 door.
But you know what? After the first few stops I learned to embrace what I couldn’t change. Stopping more frequently for gas gave me more time to get out and stretch than I otherwise would take. Made the trip less fatiguing.
But I’m no fool. To keep the stress at bay I had a full gas can strapped to the side of the camper.
For when this happened (which happened more than once)…
Ford Bronco 2DR Auxiliary Fuel Tank 9D73B73D-AD88-424D-A80B-4BD42568B472
dingle87
Reese
thats a coolant expansion tank
not your fault though, they didnt advertise it right
Welp. Back to the google machine. 😂. Fun to search and find things, then get educated. Lol
i thought it was odd i hadn’t seen it in any discussion. Hahaha
CarGuy
New Jersey
2023 Ford Bronco
I'd like to say replace the exhaust with an aftermarket the moves the muffler from the rear to middle of the vehicle and install a fuel cell (or equiv.) where the old muffler was - lots of room. But the Ford Pinto comes to mind. 🚙 🔥
grayshadow
Charles
Humble, Texas
Broncos 4 evah
Erich
Poway, CA
66 Mustang
Yep, Never had a car where 0 miles to empty meant the engine quit running. But how much grace did they really give you? Finding out empirically is annoying and painful.
