2Door Rear Seat Delete
Rhino Liner or Stain?
  • Total voters
RayB1969
Ray
Orlando Florida
Ford Bronco Badlands 2.3 SAS Lux Manual
Just finished Rear Seat Delete. Rhino Liner or Stain?
Ford Bronco 2Door Rear Seat Delete RSD3
Ford Bronco 2Door Rear Seat Delete RSD2
Ford Bronco 2Door Rear Seat Delete RSD1
Ford Bronco 2Door Rear Seat Delete R Bailey Seat Delete
Desert_Brush
SoCal
2015 Mini Cooper
UncleBrad
Brad
2024 Bronco 2-DR Manual
For my 2-door rear seat delete, I eschewed the wood and expensive Goose option in favor of a $40 thick, heavy horse mat from Tractor Supply. After removing the seats and faking out the sensors, I cut the mat to size and drilled four holes in the mat to accommodate the long bolts pressed in from underneath. The bolts fit snugly into the holes and hold the mat firmly in place, and terminate nicely just below the surface. It's grippy and washable. Everything lays flat. It looks and works great. The bolts are protected, it's lighter than the other options, helps reduce road noise and everything is easily reversible.
https://www.tractorsupply.com/tsc/product/utility-rubber-mat-black-4-ft-x-3-ft-x--frac12-in-1011848
Ford Bronco 2Door Rear Seat Delete 1750859047767-gl
Ford Bronco 2Door Rear Seat Delete REAR_SEAT_DELETE-1
SHANUT
Craig
Hermann, MO
I would love to see pictures of your install.
UncleBrad
Brad
I'm having problems posting pictures. If you can see it below, the mat is cut to size and trimmed around the seat belt bases. You can see the four holes that fit over the bolts. I just used a jigsaw and a drill to do all the work, with careful measuring. To precisely determine where to drill, you can moisten the top of the bolts with a magic marker, then gently press the mat onto them. Update: managed to upload the image by reducing its scale, changing it to a .gif and using the attach link.
straycatboat
rick
bronco 2023
This!
