Ingridthehorrible
FL
2005 Chevy 2500HD, 2008 Buell 1125R, 98 Buell S1W
Picked up Bronco this Tuesday from dealer. Have mounted a dual ARB compressor under the hood of a 2.7L Badlands. Fabricated the mount tonight, took about 4 hours. Used some aluminum that I had on hand. Also used a set of Quick Draw Brand Brackets to attach the compressor to the mount I built. Only had to drill one hole to install mount. The compressor and mount can be quickly removed in about two minutes by removing two nuts, this time doesn't include the air line or electrical. Still need to complete the air line, need to obtain some fittings and air line first and the complete the electrical. Also will be installing a 1 gallon air tank, still need to find a home for it. It's late will followup with more details maybe tomorrow. Will be removing mount to finish some of the rough edges and maybe paint black. Neither the compressor or mount rub against anything in the engine compartment
Here's some pictures.
Original space before installation
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636612578841
The two brackets attached directly to the compressor are from Quick Draw Brand https://quickdrawbrand.com/product/arb-twin-compressor-bracket-universal-mount/ Will be removing those eight bolts holding the brackets to put Loctite on them
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636612650308
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636612696874
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636612734879
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636612782259
Clearance between the compressor/mount and closed hood
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636613146874
Ingridthehorrible
Ingridthehorrible
FL
Update # 4. Completed the installation this last Sunday. Installed the air-line from the compressor to the remote 1 gallon storage tank and rear air line quick disconnect mounted on trailer hitch. Used 1/2 air-brake line and fittings, they are rated at 150 psi working pressure. Also installed two air line quick disconnects under the hood by the compressor, one has the air line going to the air tank and the back quick disconnect connected to it and the other is for for use to connect a air line at the font of the vehicle if needed. Remote mounted the compressor air filters just behind the leading edge of the hood so that the compressor has cooler air intake as opposed to the middle of the engine compartment. If needed the compressor, its mount and remote mounted compressor air filters can be removed in less than five minutes to service the compressor or vehicle components.
Built up a manifold and airlines for deflating and inflating all four tires at the same time. Started to rain so didn't have time to test the manifold and airlines. Will test the manifold and airlines this coming weekend, will time deflate and inflate times, and then post.
Pic's follow
Final Installation closeup
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1637629419443
Side view showing compressor installation with remote mounted air filters
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1637629504953
View from the front of the installation
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1637629607079
Remote compressor air filters location next two pic, ty-wrapped the air filters covers so they don't pop off.
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1637629752704
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1637629782158
Manifold Assy
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1637629854671
Manifold installed in rear mounted air quick disconnect
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1637629906493
Update # 3. Have painted the compressor mounting bracket black, reinstalled the compressor and completed the electrical. Will be next weekend for the airline installation, airline and fittings should be delivered by next Friday.
Used AUX switch # 6 to control the compressor, stripped the violet and black compressor control wiring and plug from the factory ARB control wiring harness, note the black wire is not used. Pictures follow
Compressor reinstalled with mounting bracket painted black
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636946115354
Compressor Control wiring and connection plug stripped from ARB factory harness, this was installed in Bronco using split loom
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636946338630
Compressor power cable and control wiring connected to compressor
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636946550556
Compressor power and control cable dressed along Bronco factory wiring harness
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636946693673
Compressor Control wiring connected # 6 Aux Switch wiring, yellow with orange tracer which was connected to the violet wire from the compressor
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636946791596
Compressor Power cable connection to battery
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636946960629
Update # 2. Have mounted the 1 gallon air storage tank that will be connected to the compressor for air storage and also mounted the air line quick disconnect on the trailer hitch where it is protected and easy to access. Still need to order airline and fittings to complete installation Plan to installed the electrical tomorrow. Most likely next weekend for the air line installation. Pictures follow for air tank and quick disconnect.
Space for 1 gallon ARB air storage tank in front of the gas tank
Bracket built for tank installation
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776262927
Tank with bracket installed
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776311762
Tank installed
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776367824
Clearance between air and gas tank
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776442780
Clearance above tank
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776507859
Trailer hitch before quick disconnect installation
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776591318
Air line disconnect and bracket that was fabricated
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776691928
Air line quick disconnect mounted on trailer hitch, will be making a dust cover for quick disconnect.
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776840682
Update #1. Removed the bracket so I can de-burred the cut edges, then cleaned up and paint. Also insured the air filter access wasn't impeded. Here's some additional pic of the bracket
Mount in Vehicle without compressor install
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment Compressor Mount Installed in Bronco
Mount out of bronco
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment Air Compressor Mount
Mounting bracket attachment points to Bronco
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment Compressor Mounting Bracket Vehicle Attachment points
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636776192435
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636946298656
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636946648301
TriggerTX
Trigger
Austin
61 Ford T-Bird, Autozam AZ-1, Golf R, Suburban 4x4
Going to be interested in where you can hide a tank. I haven't really spent much time under a new Bronco while thinking about that. Do you think just a gallon is enough?
Ingridthehorrible
Ingridthehorrible
FL
Am considering a second tank, only bought one to start with, if I find room for two, will source a second tank and install.
BRBlue
Houston
Toyota Tundra
Boston182
Matt
San Francisco, California
Harley Davidson Sportster
The competition to get a compressor in a 2.7 is more interesting to me than most sports.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Awesome, loving see people coming up with ways to mount things.
Nice job (y)
@4x4TruckLEDs.com Look like it fit under the hood of a 2.7.
Yes just got back from test fitting. The compressor will have to be mounted in this fashion. On the 2.3L it can go the other way but on the 2.7L this is the orientation we came up with.
Ingridthehorrible
Ingridthehorrible
FL
ROKBRNC
NorCal
2004 LJ on tons, 1970 Bronco, 2019 Tacoma TRD, 2022 Audi SQ5
I’ll just wait until Powertank comes out with their Bronco rollbar mount, no loss of floor space, drilling or wiring and can leave the tank at home when not needed and can also move it from vehicle to vehicle. Used about every hard mounted air compressor available over the years and the Powertank handles 90% of what I’ve needed from filling up tires, running air tools, air mattresses, only downside is risk of it running empty so I always refill when it gets to <30%.
Ford Bronco ARB Dual Compressor Installed - Under Hood 2.7L Engine Compartment 1636764876411
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Unsure if you're referring to sports, such as baseball and hockey, or Bronco Sports... :unsure:
Shinoko
Asheville, NC
Badlands Sasquatch
Isn't heat an issue mounting it under the hood? I thought they had some kind of thermal cutoff, seems like a few hours of wheeling would cause them to get too hot for use.
Boston182
Matt
Professional sports. Baseball, basketball, football...
But not hockey. Hockey rules and is the best.
Additional note... I like the Bronco Sport for what it is. I don't understand the shit-talk. Reminds me of my 2010 Escape, but more capable. ¯\_(ツ)_/¯
jaeggernaut
BMW M Coupe // Volvo P1800S // Caterham CSR 200
Do you need the tank if you have a compressor and vice versa? I thought you needed only one or the other (n00b off-roader)
