21 Bronco Fiberwerx Raptor Conversion kit
Martiin
Martin
Alamo tx
2021 bronco
Well my wait ended and the next part of my build has begun. I ordered the Fiberwerx raptor fender conversion kit for the bronco. I received this last week.
Let's get started with delivery. The parts came in a well wrapped pallet covered with a thick cardboard box. Inside where the fenders door trim and the front liners (rear liners are reused) overall pkg was in good shape and nothing was damaged in transit (this was my biggest fear).
Disassembly of the bronco is very easy just a couple bolt on each fender and they came off. Grill also has to come off but that's about it.
The good stuff know lol getting this panels installed. If you have some patience and not afraid to cut dril and sand you got this. My biggest fear was getting over the cutting and drilled but after the first panel it was a breeze. The panels have indentations close to where the Bolts go but you do have to fiddle with them holes to get them to line up. Front panels where yhe easiest to install. Make sure to tape the edge of your hood so you don't scratch anything and remove the doors it will make everything much easier. On the rear panels takes a bit more time because you have to cut out the holes for the lights and gas cap. Once cut you gave yo sand down so that this fits around the tail ligh. It's a process of fitting and sanding. Take your time you don't want to remove more than what you need. The gaskets cap and I went to war and thankfully I won. This was the most difficult as there are clips that need to lock for the gas cap to secure and I had to de a lot of fiber removal because panel was to thick.
I have finished the installation of all panels except for the front wheel wells wich I'll finish up this coming weekend. I'm looking at wheels and tires know because this fenders are wide and baymax looks like he skipped leg day lol. I'll update once I've installed the wheels and tires. I'll leave you with the photos I have. I'll be making a video and uploading to YouTube in the next few days. Left link to 2 short videos I made while working on panel fitting.
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231017_162744
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231017_163447
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231017_171653
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231017_171701
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231017_180353
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231019_182330
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231021_223043
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231022_210747
Ford Bronco 21 Bronco Fiberwerx Raptor Conversion kit 20231022_210753
Strykerwsu
Wichita
Holden Commodores
Seems like will need 40’s To fill all that space? Is more work required near fuel door?
Martiin
Martiin
Martin
Alamo tx
2021 bronco
I'm looking at Cooper Discovery STT Pro 37x13.5r17 and some fuel cycles 17x9 -12offset. The fuel door I got to lock but took a while to get it right.
BigMeatsBronco
Allan
2021 FE 2 door
where's the part that attaches to the rear door?
Canyon Coolers
Jason
Flagstaff
canyoncoolers.com
2002 C5 Corvette, Dodge RAM 2500, Sprinter Van 2500
[/QUOTE]
Its a whole different beast with those wings disguised as fenders on it. I'm not normally one for trying to make an orange look like an apple, but it really isn't a Raptor copy it is it's own Desert Beast except for maybe the shark gills, but I really like those.
Very Cool.
I'm about to mount he DV8 fender flares to clearance a little more uptravel. A half measure compared to your project.
Martiin
Martiin
Martin
Alamo tx
2021 bronco
You don't use the back bottom portion. The fiberglass fenders wraps around. Tail light has to be put in before fender
Martiin
Martiin
Martin
Alamo tx
2021 bronco
Martiin
Martiin
Martin
Alamo tx
2021 bronco
I don't know why/how, but I can always tell when someone's posting from Texas by looking at the photos. Good work!
Thabk you its getting there. I think It's the heat and humidity radiating off the photos that gives it away lol
Martiin
Martiin
Martin
Alamo tx
2021 bronco
Very Cool.
[/QUOTE]
Whole different beast in deed. I'm gonna have to run stock sasquatch suspension for a bit while I figure out what I'm gonna go with.
It was never the plan to go this crazy but I got a good deal on kit and couldn't resist. The gills where a bit of a bummer since they aren't vented like the raptors but I think I found a good fiberglass shop that will do finish work on them and I might have them open them and add some grill on openings.
Those dv8 tube fender are nice I'd probably go that route if I didn't he way I did.
Martiin
Martiin
Martin
Alamo tx
2021 bronco
Sorry mis read though you asked about back corner. I actually mounted those today. Was against the fence on using double sided tape or Bolts. I decided on double sided for know if they fall or have any issues I'll look into bolting them to door.
misagh
misagh
What did you do for the rear fender liner?
